Thread: Projector headlights
Results 1 to 20 of 23
  1. #1 Projector headlights
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    My wife asked me if i would like projector headlights for fathers day this year. I said ok, and she showed me what she was getting me.
    SPYDER® - Pontiac Grand Prix 1997-2003 Smoke CCFL Halo Projector Headlights
    My question is, are projector lights adjustable?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 Re: Projector headlights
    GT Level Member deadwoodspecial's Avatar
    Fuquay Varina, NC
    I had a set of lights similar to these for my '04 Intrepid, and I wasn't impressed with the light output. Trying to switch bulbs to a different brightness wasn't an easy chore, and just never seemed to have the light intensity I wanted. Looks overall were great though.
    2008 Grand Prix Base
  3. #3 Re: Projector headlights
    Ok so what would you recommend?
    Mods- Intake
  4. #4 Re: Projector headlights
    Fuquay Varina, NC
    Personally, I am really leaning towards the HID retro's. It looks like a job and a half, but from everything I see, it costs about the same if you do the work yourself, and the light output is through the roof.
    Edit: and I dont think its much difference in price from what you're looking at with the plug and plays.
  5. #5 Re: Projector headlights
    I have looked at the retro kit but i just dont want to work that hard at it.
    Mods- Intake
  6. #6 Re: Projector headlights
    Feb 2013
    Detroit, MI
    Retros where its at for performance and looks..projectors look cool n dont work great..youll need foam for them because the tend to bounce. N if you do order them off ebay instead of carid for at least a $100 cheaper.
    Sent from my SGH-M919 using Tapatalk 2
  7. #7 Re: Projector headlights
    either way there going to bounce? Wheat about the adjuster, do they have them.
    Mods- Intake
  8. #8 Re: Projector headlights
    Quote Originally Posted by GrandPrix06GT View Post
    Where would i foam them in at?
    Mods- Intake
  9. #9 Re: Projector headlights
    Feb 2013
    Detroit, MI
    From what I hear yes, never personally had them but everyone warns people on here. Take a look at this thread, maybe it will help a little.
    http://www.grandprixforums.net/anoth...ion-33447.html
  10. #10 Re: Projector headlights
    Dec 2008
    Lawndale, CA
    I had a set of these for about a year before I went back to stock lights. The bouncing gets old after awhile even after trying all of these bounce fixes. They do look cheap so don't high expectations. They do have adjusters on them. They leave weird gaps if you try to adjust them to avoid the beams crossing. I had mine adjusted pretty good. If you do end up getting these be sure to add HIDs to them. The halogens in them are not that great. If I were to go projectors again I would retro.
  11. #11 Re: Projector headlights
    Quote Originally Posted by The Guz View Post
    I had a set of these for about a year before I went back to stock lights. The bouncing gets old after awhile even after trying all of these bounce fixes. They do look cheap so don't high expectations. They do have adjusters on them. They leave weird gaps if you try to adjust them to avoid the beams crossing. I had mine adjusted pretty good. If you do end up getting these be sure to add HID's to them. The halogens in them are not that great. If I were to go projectors again I would retro.
    I would buy the HID kit. I have the stock in mine right now, with the hid kit, i did adjust them so i wasn't just seeing the road, and they bounce, and have the weird gap in the bottom. I just wonder if i put the hid in wrong. Is there a certain way they need to go in? Either way im going to need new headlights, because i broke the adjuster screws on them.
    Mods- Intake
  12. #12 Re: Projector headlights
    Dec 2008
    Lawndale, CA
    Another thing I forgot to mention is that these use a different bracket than the stock lights. So if you break the bracket, you either fix them or buy a whole new set. There is no replacement bracket for these.
  13. #13 Re: Projector headlights
    But they would bolt right to the stock location?
    Mods- Intake
  14. #14 Re: Projector headlights
    Dec 2008
    Lawndale, CA
    They do. I'm just letting you know the overall bracket that holds the actual headlight is different and there is no available replacement if one is broken.
  15. #15 Re: Projector headlights
    ok. thanks for all the information. ill have her read it and well talk about it.
    Mods- Intake
  16. #16 Re: Projector headlights
    GTP Level Member 2001goldGTP's Avatar
    california
    I have those with the CCFL and HIDs 4300K bulbs. they can be adjusted up and down and side to side. you just need to be gentile with them. I even took a little preempted stick on them and used some plastic jb weld around the bolt holes to firm them up.
    As for the bounce, there are a lot of cheap and easy ways to fix them, i fixed mine with some double sided tape and spray paint can lids.
    Most people that break them try to fix the bounce by over tightening the bolts, that does nothing to help. i keep mine at finger tight plus a 1/4 turn with a wrench. works fine.
    also the CCFL halos are super bright, they can been seen in the direct sun light. I have had mine now for over two years, same ebay HID kit same head lights and halos, no issues, it all about prep work and getting the correct power harness for the HID blasts.
    here is a daytime pic of just the halos
    xp'd
  17. #17 Re: Projector headlights
    Quote Originally Posted by 2001goldGTP View Post
    The HID fit with no problem. ok I love the look of the halos
    Mods- Intake
  18. #18 Re: Projector headlights
    california
    H1 HID bulbs
    xp'd
  19. #19 Re: Projector headlights
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  20. #20 Re: Projector headlights
    SE Level Member black97GT's Avatar
    Mar 2013
    OHIO
    I replaced my factory hazed over headlights a few years ago with some cheap 'Eagle Eye' brand from ebay. Passenger side is now broken and bounces when going down the road. Looking at buying replacement ANZO Search results for: 'Pontiac-Grand Prix-1997' headlights with Halo rings. Anyone have experience with these? Fit, finish and function ok? Also, there are ones on this link that do not have halos that look stock only tinted dark inside. Thoughts or experience with these?
  1. projector headlights
    By Spartanzz in forum Visual/Body Modifications
    Last Post: 08-26-2011, 11:33 PM
  2. looking for projector headlights
    By beckys2000gt in forum Shops and Community Heroes
    Last Post: 03-06-2010, 11:35 AM
  3. projector headlights
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 09-04-2009, 12:06 AM
