Thread: question about interior led's
Results 1 to 3 of 3
  1. #1 question about interior led's
    GT Level Member Shiftingshaddow's Avatar
    KC
    the previous owner had leds installed in the headlights and in the interior. the ones in the head lights work as designed but the interior lights don't. when i bought the car they didn't work at all so i didn't see what they even looked like. one day they randomly came on and i thought, "oh, that's cool." but they wouldn't turn off when i turned the car off. i checked how they had them wired under the hood and it looks like it was a bad ground as to why they wouldn't work at all. so i fixed the ground connection properly and they work but they still don't turn off when you shut the car off.
    my assumption is they are on some sort of remote like an amp would be but i'm not sure where that connection would be. there are no wires run for the led's behind the stereo for this application. when i dug around the dash a bit there is some sort of module tucked between the console and firewall but i couldn't lay down to see it at the time. the led's were plugged into this module but i'm not sure where it is hooked to. what is going through the firewall is a blue coated wire-a power and a ground that appears to be separate from the module. the power is hooked to the fuse box and the ground is hooked to the strut support bolt.
    i don't have pics of this and i'm not really sure i can get the pics of the module because its mounted upside down behind the console.
    has anyone dealt with a similar setup?
    i thought about just rigging a switch up but if the right way is within reach then i will go with that.
    oh, she said they worked fine and she was actually surprised they weren't coming on when she showed me the car. she also took her head unit out that day before i came so i'm thinking the two are connected. i just don't see any separate remote wire in the dash for the led's. she also blew the amp fuse in the dash somehow. when i put my stereo in it wouldn't work at all so i traced it to that blown 20 amp "amp" fuse.
    (edit) oops. i put this in the wrong section by mistake. meant for it to go in the interior catagory
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #2 Re: question about interior led's
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I have led lights but they are in all the Reg sockets and work correctly lol
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: question about interior led's
    KC
    the ones in the headlights work fine. it is a series of them, like in an audi or something. there is the regular headlight bulb but the led's are laced around the lense.
    the interior ones are like strips of led lights. there are three of them and you stick or mount them where you want them. they look neat when they work. i wouldn't have put them in myself, though.
  1. 97 gt interior lights question
    By Logan541 in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2013, 04:00 PM
  2. LED interior lights question
    By Max Cook in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 10:04 PM
  3. HELP ME PLEASE!! interior lights question
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2012, 05:00 PM
  4. interior lights/exterior lights newbie question
    By spider4 in forum General Tech Discussion
    Last Post: 11-10-2011, 08:34 PM
  5. 04+ interior lighting question
    By jpdubrall84 in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2011, 11:29 AM
