I just put a new window regulator and motor in my 01 gtp coupe and I'm having issues with the bolt holes lining up on the bottom of the window and the regulator. I can barely get the bolts to go in but then the window must be too far forward because it goes up about half way then gets stuck on the front, tilts forward and won't go up. When I put the rear bolt in only it goes up just fine but the hole on the front doesnt come close to lining up with the hole on the regulator to bolt in. Is there some trick to doing this?
I appreciate the help
Thanks,
Randell
