Thread: need help with my door
Results 1 to 8 of 8
  1. #1 need help with my door
    Dec 2012
    Philadelphia Pennyslvania
    when i got the car this piece of trim was missing. i want to go the junkyard and get a new one im just not sure how to get it off of the car. i was thinking that i would have to pry it off with a crow bar or something without messing up the paint of course. how should i go about getting the part off and what tools should i bring with me thanks for any help
  2. #2 Re: need help with my door
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    It should just be held on with plastic clips id imagine a flathead would do the job just be careful you dont break it... dont quote me on that though
  3. #3 Re: need help with my door
    take the inside of the cars door off, and push the clips out. pliers work well to compress the clips.
  4. #4 Re: need help with my door
    Dec 2012
    i havent heard the idea of taking the panel off and pushing the clips out. im going to try that. if not im breaking out the crow bar. any screws or bolts holding it on?
  5. #5 Re: need help with my door
    Dec 2012
    Akron
    when i peeled one off the other day i dont remember seeing any clips i just used a flat head screw driver and pried it off
  6. #6 Re: need help with my door
    Dec 2012
    Hawai'i
    So are there plastic clips? I have a loose trim piece and would like to fix it
  7. #7 Re: need help with my door
    Dec 2012
    yes there are im not sure if they work very well though
  8. #8 Re: need help with my door
    Apr 2011
    KC Area, Missouri
    My '99 did not have clips, only guide pins for correct placement. There is also a channel on the bottom of the door that the trim slides up into to hold it in place. It was held on with double sided foam tape. Free the top of the molding carefully with tool of choice (i used exacto blade and nylon pry tools) and then slide molding down to remove. Worst part was removing all the old foam tape.
    Regards
    edit: Sorry I think I misunderstood: The channel at bottom of door holding the molding is attached with clips and rivets.
