Thread: 97-03 Retrofit Resources
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 97-03 Retrofit Resources
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    It seems like there is always a new thread about someone wanting to retrofit. When these posts pop up members are helpful, but often no longer remember or have all of the info/links they used when they did their retro. So I decided to post all of the links I found helpful when I was in the process of retrofitting mine. Hopefully this will help give people a kick-start for their project. If others have links they found helpful I suggest they post them and we try making a giant resource thread.
    The links I posted may not be specific to the grand prix however, the more you read you will find new ideas, tips, and tricks to help you with your retro fit. The key to a good retrofit is patience.
    I bought all of my stuff from The Retrofit Source, however you are free to shop around:
    The Retrofit Source online: headlight upgrades for all applications
    How-To's:
    http://www.grandprixforums.net/how-r...ml#post1003206
    http://www.grandprixforums.net/retro...ics-77252.html
    retro threads: (good for background and general tips)
    http://www.grandprixforums.net/clean...ork-42444.html
    http://www.grandprixforums.net/think...ons-58686.html
    Grand Prixs Of North America • View topic - The Projector Retro Thread
    Grand Prixs Of North America • View topic - Let there be LIGHT! (Morimoto Projector Retrofit)
    http://www.grandprixforums.net/boost...1-a-43110.html
    97 Grand Prixd GTP Morimoto H1 Mini
    How to: Morimoto Mini H1 Bi-xenon Projector Retrofit
    ClubGP Message Forum troubleshooting
    How To Aim Projector Headlights - Club RSX Message Board
    Troubleshooting:
    Problem with Bi-Xenon Harness, Need Help from Retrofitters! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
    Mini H1 woes
    High beams always with solenoid hooked up........
    HID info:
    How To: Install HID's - Grand Prix Net
    http://www.grandprixforums.net/hid-c...ion-39737.html
  2. #2 Re: 97-03 Retrofit Resources
    Jul 2010
    Coquitlam,BC,Canada
    Awesome post. This should be a schticky!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    haha we'll see. i posted these once for matt palm in his retro thread when he first started it, and others thought it should be stickied aswell. just never happened. I decided to make a thread solely for the links in hopes that it would be easier for others to find.
  4. #4 Re: 97-03 Retrofit Resources
    antioch ill
    i will be doing them once tax return gets here
  5. #5 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    nice, good luck. probably the most important thing to have is patience. I hope you didn't feel like i was calling you out. haha. I was just saying that the links were posted elsewhere and that thread was never stickied, which was the reason i made a separate thread with a title that pretty much says "links for retro in here". Hopefully this will be easy to find.
  6. #6 Re: 97-03 Retrofit Resources
    antioch ill
    haha i know i just never got around to it but my headlights now are making me angry. I have my stock headlights so ill just use those
  7. #7 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    I would suggest having a second pair, unless you can live without your car for atleast a couple days. mine took me roughly 3 days but i painted my housings black and i chipped them when removing the lens so i had to do some repair work using a JB weld stick
  8. #8 Re: 97-03 Retrofit Resources
    antioch ill
    i have projectors now and my old ones sitting in the attic
  9. #9 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    oh i see. i had a lot of trouble taking the lens off. I also heard a wide range of temps and times used when baking them to loosen the adhesive. the plastic lip on the housing gets very brittle when you heat it so if its not budging more heat or more time, or both.
  10. #10 Re: 97-03 Retrofit Resources
    antioch ill
    what kind of heat did you use
  11. #11 Re: 97-03 Retrofit Resources
    I did like 220º for 10-15 minutes. If it didnt want to move, I left it in there longer. But being careful is key, like said above the plastic housing does get soft.
  12. #12 Re: 97-03 Retrofit Resources
    antioch ill
    i dont want chrome capsules how easily can they be painted
  13. #13 Re: 97-03 Retrofit Resources
    Scuff them, clean and paint. I used a 3m red pad and worked great.
  14. #14 Re: 97-03 Retrofit Resources
    antioch ill
    mmmm black housings black capsules with silver on the front edge
  15. #15 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    Quote Originally Posted by Matt LE-FAG Palm View Post
    I think i got up to 270ish and i started to get the lens to peel off. but then it got tougher and i started to pry, thats when it chipped. i thought i read somewhere someone said 350 for removing the lens. it really depends what sealant is on the headlight. start low work your way up.
    As for the painting, sand lightly or scuff, clean, spray.
    **edit: oh and because the edge of the lens is textured (gives a frosted like appearance) you don't really see the edge of the inside of the housing. So after you get the lens off, if you wanted to do a 2 tone type of deal you might want to check how much of the inside edge of the housing you actually see.
  16. #16 Re: 97-03 Retrofit Resources
    Never Never Land
    For scuffing I used a green scotch brite...worked great for getting the back of the housing.
  17. #17 Re: 97-03 Retrofit Resources
    antioch ill
    i was talking about the capsule with the actual projector part
  18. #18 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    the shroud? i didn't really paint mine so i can't say for sure, but if your going a completely separate color that the chrome i would imagine its the same idea
  19. #19 Re: 97-03 Retrofit Resources
    antioch ill
    well i just dont want a chrome shroud i want it black
  20. #20 Re: 97-03 Retrofit Resources
    Same thing applies, just scuff the shroud up and paint it.
  1. Projector retrofit in a '97-'03
    By barnettimpala in forum Visual/Body Modifications
    Last Post: 02-15-2013, 05:43 AM
  2. retrofit headlights 04 to 08
    By carlover89 in forum Off Topic Discussion
    Last Post: 12-14-2011, 03:21 AM
  3. Retrofit help
    By DukesGTP in forum Visual/Body Modifications
    Last Post: 12-04-2011, 06:04 PM
  4. Retrofit help
    By GPGT2004 in forum Visual/Body Modifications
    Last Post: 07-07-2011, 03:12 PM
