Thread: 97-03 Retrofit Resources
Results 21 to 40 of 55
  1. #21 Re: 97-03 Retrofit Resources
    antioch ill
    so im guessing the lens comes out or something
  2. #22 Re: 97-03 Retrofit Resources
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    ya the projector and shroud are two separate pieces (well if you buy from TRS anyway) and the shroud just gets screwed to the projector
  3. #23 Re: 97-03 Retrofit Resources
    Never Never Land
    When I painted mine I used oven cleaner to strip all the chrome off. Then scuffed with the green scotch brite.
  4. #24 Re: 97-03 Retrofit Resources
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    200 degrees for 20 minutes worked for my camaro's headlights when I did a retrofit, so I'm going to try that again.
  5. #25 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    Well never mind, I'm doing this now and the headlight part is giving me a hard time. The corners came apart easy.
  6. #26 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    So I didn't read every single thread you posted, but it looks like you have to cut the shrouds for the Mini H1 projectors? Mine won't fit inside the housing.
  7. #27 Re: 97-03 Retrofit Resources
    Yeah you have to hack like half of the shroud away. Top and bottom, this is just a general idea of how much you will need to take off. I have to trim mine more even after those cuts.
  8. #28 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    Top and bottom will need cuts like that? Damn.
  9. #29 Re: 97-03 Retrofit Resources
    Never Never Land
    Yup...they need quite a bit of hacking up.
    The back has to be cut so you can tighten down the lock ring...here's what I cut.
  10. #30 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    Oh yeah I figured the back would need to be cut when I pulled these from my car.
  11. #31 Re: 97-03 Retrofit Resources
    Detroit, Michigan
    ya shroud has to be cut. take your time and you should be okay. in one of the links it shows you the way to cut the shouds. they will look just like what Fivefingerdeathpunch posted.
  12. #32 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    Thanks guys I'm going to start doing all the cutting now. Snapping pictures as I go, I'll probably make a thread about it.
  13. #33 Re: 97-03 Retrofit Resources
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by LS1GTP View Post
    Please do. I am waiting for my parts to arrive (5 days later and TRS still hasn't shipped my order).
    The 97-03 community needs more detailed info on the retrofit; Clean's pics are gone, and one other guy that took good pics are all blurry and hardly legible. I have a good idea of what needs to be done, but I like pictures!
    I was blown away with all the threads with a few final pics, and saying "I'll post more pics later". Some of these threads are 2-3 years old, and said pictures have not been posted.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #34 Re: 97-03 Retrofit Resources
    Sep 2012
    Clarkston, MI
    My stuff got here 4 days after I ordered, same with last time I retrofitted. TRS has been one of the best companies to deal with, hands down.
    I cross threaded one of the projectors where it gets 'held down' so to speak...TRS is shipping that part of the projector (the bowl part) so it's going to take a little longer for me to get this project done.
  15. #35 Re: 97-03 Retrofit Resources
    I wish the quality of the nut and bowl were better, they can cross thread even doing it by hand. And after a few times of going on and off, metal/plastic or whatever the material is starts to leave shavings behind.
  16. #36 Re: 97-03 Retrofit Resources
    antioch ill
    dumb question i already have ddm h1 bulbs, harness,and ballasts. im guessing i can reuse those but they are only low beams not bixenons. so how do the bixenons work exactly are there bulbs for that im guessing. and im pretty sure i could reuse the same ballasts and harness over
  17. #37 Re: 97-03 Retrofit Resources
    Never Never Land
    The harness won't work. You need a harness from TRS. The high beams on a bixenon projector are achieved by moving the cutoff shield. Inside the projector you have a cutoff shield with a plugner attached to it. The TRS harness has one side that powers the bulbs. When you flip the high beams on with the switch on the column, you supply power to those plungers which pull the cutoff shield down, raising the beam(high beam). The TRS harness is needed because in a regular 9007 application like ours, when you turn the high beams on, the low beams turn off. So if you were to try to wire them yourself, when you turn the high beams on, the cutoff would flip and the bulbs would turn off. TRS's harness has a relay that takes care of that issue and keeps power going to the bulbs and the plungers both to have a high beam
    So...yes your DDM bulb and ballasts will work perfectly fine, although they might not be as bright/effecient as TRS's, but that's a different matter.
    No, your DDM harness will not work for a bixenon function, only a low beam.
  18. #38 Re: 97-03 Retrofit Resources
    Never Never Land
    Also as a note for that TRS bixenon harness. You may have to switch the pins around. On mine they were backwards. I don't remember exactly what mine did but they acted all funky. Swapping the outer(IIRC) two pins around fixed my problem, as it has for lots of other people.
    IIRC they do this because the harness is compatible for both 9004 and 9007 sockets but they high and low beam circuits are opposite.
  19. #39 Re: 97-03 Retrofit Resources
    antioch ill
    alright thanks. I was hoping I didnt have to get all that lol. would of saved A LOT of money. but id rather have the proper stuff for it to work better
  20. #40 Re: 97-03 Retrofit Resources
    antioch ill
  1. Projector retrofit in a '97-'03
    By barnettimpala in forum Visual/Body Modifications
    Last Post: 02-15-2013, 05:43 AM
  2. retrofit headlights 04 to 08
    By carlover89 in forum Off Topic Discussion
    Last Post: 12-14-2011, 03:21 AM
  3. Retrofit help
    By DukesGTP in forum Visual/Body Modifications
    Last Post: 12-04-2011, 06:04 PM
  4. Retrofit help
    By GPGT2004 in forum Visual/Body Modifications
    Last Post: 07-07-2011, 03:12 PM
