Thread: So I had a foglight burn out last night.... upgrade time?
Results 21 to 40 of 47
  1. #21 Re: So I had a foglight burn out last night.... upgrade time?
    antioch ill
    and wrapped in a bagillion grocery bags
    Ohio
    It's all I had hahaha
  3. #23 Re: So I had a foglight burn out last night.... upgrade time?
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by LS1GTP View Post
    Anyone have these? Wouldn't have an issue with heat.
    2 PC 7W High Power Xenon White 880 881 LED Bulbs for Car Fog Lights or Driving | eBay
    I'd put them in mine but my fogs are starting to melt and if I pulled a bulb out, I don't think I'd get another bulb to stay in correctly. So I'm going to need new housings.
    You would have no issues. But they won't provide any usable light. These would be mostly for looks.
  4. #24 Re: So I had a foglight burn out last night.... upgrade time?
    Antioch, IL
    Advance auto special. $29 4" blazers
    Uploaded with ImageShack.us
    uses stock metal bracket. few aluminum spacers from ace flip the fog upside down and walla direct bolt in.
    2009 Challenger SRT8
    Expert at being gay.
    Ohio
    Quote Originally Posted by ITHURTZ View Post
    Exactly. Except I used two bolts and two locking nuts. Either way it still works great.
  6. #26 Re: So I had a foglight burn out last night.... upgrade time?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Quote Originally Posted by 99PGPGT View Post
    Burgundy, I'd like to go out on a ledge and say that it was your passenger side that burnt out?
    Holy crap if I had a cookie you would be getting it! Howd you know? lol
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  7. #27 Re: So I had a foglight burn out last night.... upgrade time?
    Are these the aluminum housing with glass lens as well?
  8. #28 Re: So I had a foglight burn out last night.... upgrade time?
    antioch ill
    im pretty sure they are considering he runs hids also
  9. #29 Re: So I had a foglight burn out last night.... upgrade time?
    Alright. Well if anyone has before and after pics of light output with just the HID foglights that would be appriciated. Along with the color temp of the bulb.
  10. #30 Re: So I had a foglight burn out last night.... upgrade time?
    antioch ill
    35w 6k
  11. #31 Re: So I had a foglight burn out last night.... upgrade time?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    ^ Why does it look like only your passenger fog is on?
  12. #32 Re: So I had a foglight burn out last night.... upgrade time?
    I'm leaning toward 5K or 6K. Also a 55W would be brighter than a 35W and if I would go 55W would I need to rewire anything to do it?
    55w also produce more heat that could potentially cause the chrome to flake (didn't see what dogs you were running and also shorten the lifespan of your bulbs. IMO if your set on hids stick to 55 watts and no you do not need to rewire it I would run a harness though.
    04 Comp G.
  14. #34 Re: So I had a foglight burn out last night.... upgrade time?
    I haven't really decided on the fogs I will be getting yet. Not going to use the stock ones for sure. I don't want to run around replacing bulbs all the time either. I may look into the 35W if that gives the bulbs more life.
  15. #35 Re: So I had a foglight burn out last night.... upgrade time?
    Antioch, IL
    35w is PLENTY. 35 fogs 35 headlights= sun never went down
    Ohio
    Cuz that's my car and both are on.
    Ohio
    Quote Originally Posted by burgundybullet View Post
    Cuz there is nothing to protect the back of the fog housing and bulb like there is on the driver side. I ended up using vinyl flooring mat to make a splash shield.
  18. #38 Re: So I had a foglight burn out last night.... upgrade time?
    Okay I guess it kind of makes sense. I'll keep it in mind when I put in HIDs.
  19. #39 Re: So I had a foglight burn out last night.... upgrade time?
    Does anyone have past experience with these? Hella H71010451 Optilux 2500 Angel Eye Fog Lamp Kit Round
    Are they decent for the money and will fit my needs do you think?
  20. #40 Re: So I had a foglight burn out last night.... upgrade time?
    Dec 2008
    Lawndale, CA
    I have them. The reason I got them was because I wanted a light with a clear lens. I don't have the halo's hooked up but from what I saw, they aren't that bright from far away. The halo is lit by two 194's size LEDs back to back. They perform just like any other driving light.
  1. Time for an upgrade, lol
    By ctracer in forum Track Sessions and Kills
    Last Post: 06-16-2012, 11:06 AM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. Time for first brake job. To upgrade or not???
    By Poseidon215 in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2010, 04:17 PM
  4. time for a suspension upgrade
    By cms3z in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2010, 11:23 AM
  5. Time to upgrade!!!
    By WackyWRZ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2009, 11:19 PM
