Thread: Bolt pattern
Results 1 to 6 of 6
  1. #1 Bolt pattern
    SE Level Member rhenuset's Avatar
    winnipeg
    I am looking for aftermarket rims but its hard finding decent ones with 5x115 bolt pattern and I have read some forums and guys saying they have used 5x114.3. I'm a little skeptical about using this bolt pattern but I'm sure it will work just don't know how well? I have a gp gt with 17" rims and would like to go up to 18s would 18x8 work for front and rear cus I also know the gxps have different size front and rear rims being 18x8 and 18x7?
  2. #2 Re: Bolt pattern
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I have heard that they have different size wheels as well. I've got Mustang Bullitts on now (5x114.3) that are 17x8 I believe (not 100% sure on that) and have no rubbing when I turn the wheels. If overall they are the same diameter as stock wheels and tires I would think they would fit.
    Edit: Don't have Bullitts on anymore. Put T-Stars on for winter.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Re: Bolt pattern
    Ohio
    Yes, 114.3 works just fine.
    18x8 is also a very safe size to run with a set of 245/45/18 tires
  4. #4 Re: Bolt pattern
    I live here. TLSheff's Avatar
    Yes 115x5 or 114.3x5 will work as well. You just have to make sure that the central hub bore will work on the wheels. Most aftermarket wheels have a larger central bore but some do not and other car companies such as Eclipses, some Mazdas, etc... but they use a smaller hub bore so the center won't fit and the wheel will not bolt up.
  5. #5 Re: Bolt pattern
    winnipeg
    Quote Originally Posted by 99PGPGT View Post
    would a 235/45r18 would too or do you think it would be too narrow?
  6. #6 Re: Bolt pattern
    It will work but it will be a little shorter than factory and throw off the speedo.
    stock height is 26.6" - 225/60/16
    go to Tire size calculator
    plug in the stock 225/60/16 and then whatever size you want to get and it will show the difference and speedo %.
    245/45/18 is about as close as you can get with 18s.
  1. Bolt pattern help
    By Bessesen2 in forum Tires & Wheels
    Last Post: 11-18-2012, 12:20 AM
  2. Right size, right bolt pattern, yes?
    By bigtom9492 in forum Tires & Wheels
    Last Post: 05-14-2012, 10:14 PM
  3. How to get 5x114.3 bolt pattern to fit
    By nascartech in forum Tires & Wheels
    Last Post: 01-19-2010, 02:45 PM
  4. whats my bolt pattern
    By tjsmithey in forum Tires & Wheels
    Last Post: 10-24-2009, 07:55 AM
  5. bolt pattern
    By jprovinsal in forum Tires & Wheels
    Last Post: 05-13-2009, 04:13 PM
