Thread: Is this clear coat?
Results 1 to 19 of 19
  1. #1 Is this clear coat?
    Sep 2012
    St Louis Missouri
    im not sure whether i should use these on my tail lights or not, for tinting.
  2. #2 Re: Is this clear coat?
    No.
    Really you should use clear coat with some black in it from a paint spray gun to get it done right.
    Otherwise you need VHT spray tint and some skills.
  3. #3 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    im using vht right now, but at the end you usually clear coat. so i was wondering if either of these would be a clear coat that is necessary.
  4. #4 Re: Is this clear coat?
    I never clear coated mine and they turned out super glossy on my old car.
    But if you want clear them, then polish to bring the shine back. I not sure I'd use those.
  5. #5 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    what are these for? but yeah that was my plan. i want to do a few coats of clear to protect the finish.
  6. #6 Re: Is this clear coat?
    Couldnt tell ya, I just read enamel and think of that as not a clear coat for paint. And I dont read on the other one where it says its a clear coat for paint.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    If you has pro skills use epoxy.
    No idea what kind my friend used but he used an epoxy over the tint and holy crap they turned out like glass. Best part is the durability, he basically never needs to polish them at all and water rolls off too.
  8. #8 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    i mean if i cant use either of the two things in the picture, im going to have to go to the store anyway, so im just going to get a for sure clear coat. these are two things i found in my cabinet that looked like they could be clear coat. does anyone else know for sure?
  9. #9 Re: Is this clear coat?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Um... spray it and find out? We can't even see what the caps are so there is no way to tell.
    GPONA #1 Cyber Bully
  10. #10 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    cap included?.. i sprayed it and it seems to be clear, but im not sure if it will work good for tinting tails. my friend some how messed his up clear coating, but im not sure how, i just dont want to end up with a dull outcome.
  11. #11 Re: Is this clear coat?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    If you don't feel comfortable using it then go to the store and buy something that you do feel comfortable with. It isn't that complicated.
  12. #12 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    i mean im no painter, i dont know if i should feel comfortable using it or not.... thats why im asking..
  13. #13 Re: Is this clear coat?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    If you don't feel comfortable then don't do it. Read up, practice and wait till you know what you are doing.
  14. #14 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    Alright i just went and bought some. It wasnt glossy/clear, but i got some correct stuff.
  15. #15 Re: Is this clear coat?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    If you want a glossy finish you should have gotten glossy paint. What kind did you get?
  16. #16 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    Idk some duplicolor clear coat stuff, it doesnt say glossy but its def not dull. Turned out good and shiny.
  17. #17 Re: Is this clear coat?
    Waukesha, WI
    rattle can clear turns yellow especially that krylon crap
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  18. #18 Re: Is this clear coat?
    Sep 2012
    St Louis Missouri
    Then ill have to fix it when it does.
  19. #19 Re: Is this clear coat?
    Waukesha, WI
    why do it twice?
    RayRay
    92 Turbo miata
    02 lexus is300
  1. clear coat
    By Logan541 in forum Visual/Body Modifications
    Last Post: 07-30-2011, 07:01 PM
  2. Coats of Clear Coat
    By tdm571 in forum Visual/Body Modifications
    Last Post: 05-26-2011, 03:28 PM
  3. clear reflector for clear corners?
    By ndgprix in forum Visual/Body Modifications
    Last Post: 03-26-2011, 10:55 PM
  4. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
  5. Clear Coat or Straight Aluminum?
    By FurianofLight in forum Tires & Wheels
    Last Post: 05-09-2010, 12:14 PM
