Thread: Installed new mirrors w/blinkers
Results 1 to 7 of 7
  1. #1 Installed new mirrors w/blinkers
    Oct 2012
    WY
    Last week I installed some new mirrors. I need help installing the wiring for the blinkers/brake light.
    Here is an image/gif of the mirrors.
    http://d3d71ba2asa5oz.cloudfront.net...w-ab-sm__1.gif
    I drive a 2001 Grand Prix Gt 4 door sedan.
    Any advice on the best/easiest way to complete this would be appreciated.
  2. #2 Re: Installed new mirrors w/blinkers
    Tap them into the blinkers on the corner lights?
    That's what was done with my halo's.
    Otherwise, not so sure...I'm not a wiring guy.
  3. #3 Re: Installed new mirrors w/blinkers
    Not that you give us enough info, we need more. Who made them..what they have for connections etc.
    Overall though, tap them into the rear turn signal. That way they don't come on and stay on at night.
  4. #4 Re: Installed new mirrors w/blinkers
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I'm pretty sure I read somewhere that you can splice into the wires at the steering column. Perhaps explore that option. I have Monte mirrors that I am in the process on. I will update if I should finish before you.
    02 sedan, top swap
  5. #5 Re: Installed new mirrors w/blinkers
    Oct 2012
    WY
    They're from ZS Racing.
    Here's a pic from the inside.
    http://d3d71ba2asa5oz.cloudfront.net...w-ab-sm__2.jpg
    And here's the wiring schematic they gave me.
    http://d3d71ba2asa5oz.cloudfront.net...mem-g2-3ew.jpg
    Could I connect the ground inside the door panel or should I go outside of it for that?
  6. #6 Re: Installed new mirrors w/blinkers
    Hold on a second on that.
    Here is what I would do, it's only what I consider the best, easiest and cleanest way...so trust me when I tell ya how I'd do it. I used the factory pins and location in the factory connectors for my puddles and directionals.
    I'd get the mirror side of the connector from a stock car with about 3-5 inches of wiring left on it. Then you connect your mirror to those wires, because you are going to have ground, up/down, left/right etc in that one connector. No reason to connect a ground to the structure of the door, when GM has a ground there for you to use in the wiring.
    On the blinkers, I tapped in either at the bcm or where they ran along the body. All you need to do is find the schematic that tells you which wire and you are good.
  7. #7 Re: Installed new mirrors w/blinkers
    Oct 2012
    WY
    I used the wires from the old mirrors for the motoring. So, I'm not worried about that. It's just the wires for the blinkers/parking light I'm not sure on. Anybody know where I can get the car wire schematics or should I go to a dealer?
  1. HELP!! NO blinkers/hazards!! 95 3.1
    By cb43x in forum General Tech Discussion
    Last Post: 02-14-2011, 10:12 PM
  2. no blinkers after halos and led tails?
    By 98GRANDPRIXGTP in forum Visual/Body Modifications
    Last Post: 03-21-2010, 09:20 PM
  3. HUD only displays speed and blinkers
    By rabithd in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2009, 05:23 PM
  4. blue lights and blinkers
    By smittrailfire in forum Visual/Body Modifications
    Last Post: 10-03-2008, 08:55 AM
