Thread: Engine bay cleaning
Results 1 to 9 of 9
  1. #1 Engine bay cleaning
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    This weekend I was cleaning my car by doing everything, Wash,Wax, interior, also the engine bay because after the motor warms up and I'm at say a stop light for a min or so when I take off i smell burning oil. To find where the oil was built up at I took off the plastic cover thing and started looking around. This is what I found lots of oil residue and some possible water because of wash/slight wipe down of engine with damp cloth. Anyone know a good cleaner that I can clean this up with and also how to clean it, like would I cover up the alt, coil packs? I have some type of foaming cleaner in my garage but it says not to use an aluminum.
    http://i.imgur.com/JWAUY.jpg
    http://i.imgur.com/bQNgd.jpg
    The gunk is build up like this on both sides of the plastic intake, and near the exhaust in the front of the car I'm not sure about the rear. I plan on cleaning this next weekend along with changing the tranny fluid because its a red/brownish color.
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Engine bay cleaning
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Put a big drip pan under the engine and bathe it in brake cleaner.
    GPONA #1 Cyber Bully
  3. #3 Re: Engine bay cleaning
    Lapeer,MI
    I can tell you to now spray around the ABS module.. Especially if the wiring is loose.... My worked perfect till I pulled the engine and power washed under the hood.. I had the abs connector off at the time because I was gonna put some dielectric grease on it and my buddy did some power washing with out paying attention to spraying around the abs module.. Hooked it up after engine install ( didn't change anything other than engine) and now its no workie.
  4. #4 Re: Engine bay cleaning
    Purple power or some sort of engine cleaner, and let it sit for a while and spray away.
    Its likely that you need to replace your valve cover gaskets, becuase thats where the oil is coming from.
  5. #5 Re: Engine bay cleaning
    Apr 2012
    Dayton, OH
    I found some stuff in my garage called Simple Green, I seen other people use it so I'm assuming it would be fine. Would it be okay to pressure was around the exhaust because that I'm pretty sure is where the smell is coming from.
    2012 F150 STX
  6. #6 Re: Engine bay cleaning
    yup, just spray away.
  7. #7 Re: Engine bay cleaning
    Apr 2012
    Dayton, OH
    Would it be necessary to cover the coil packs and alt?
    2012 F150 STX
  8. #8 Re: Engine bay cleaning
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I always do, if you choose not to then just don't spray directly on them
  9. #9 Re: Engine bay cleaning
    When it rains, does the motor get wet? Or when you go puddle jumping?
    Its fine, spray everything, it dont matter, let it dry if you want, or start it up and enjoy, it might miss fire a few times, but whatever.
  1. cleaning the engine..
    By Mikey Bonefas in forum General Tech Discussion
    Last Post: 07-25-2012, 01:48 PM
  2. Cleaning Engine Bay
    By SupaCharg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:20 PM
  3. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  4. Cleaning up the engine bay
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 03-23-2009, 01:44 AM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
