Thread: Brackets for Pilot fog lights......
Results 1 to 13 of 13
  1. #1 Brackets for Pilot fog lights......
    Moore, Oklahoma
    I know many of you have aftermarket fog lamps. How are you guys making custom brackets to make these work? I'm looking for a setup that will reuse the stock adjustment setup, much like the MSP brackets do. I'd rather make some than to spend $40 + shipping for some damn brackets.
    BTW, I have 4" Pilot Fog lights from Autozone....
    Shawn W. Larsen
  2. #2 Re: Brackets for Pilot fog lights......
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    X2 I would like to know also.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: Brackets for Pilot fog lights......
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  4. #4 Re: Brackets for Pilot fog lights......
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  5. #5 Re: Brackets for Pilot fog lights......
    Port Hope Ont,Canada
    I seen a nice little write up
    for making brackets and i will look for it for you.
    Off hand i do not remember were it was i seen it
    but as soon as i find it i will post it up...HTH's
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  6. #6 Re: Brackets for Pilot fog lights......
    Moore, Oklahoma
    yeah, please let me know! I want to get this project rolling next...
    Shawn W. Larsen
  7. #7 Re: Brackets for Pilot fog lights......
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  8. #8 Re: Brackets for Pilot fog lights......
    Wessington Springs, SD
    i recently put these fog lights in my 04 grand prix gt with tin flashing...i took a little piece and stuck it behind the factory fog light hole and drew the circle of the fog light hole...then marked where the factory hangers are for the factory fog lights to put holes in the flashing where bolts were used to hold it in place..i then placed the halo fog lights somewhat centered in the hole that i drew from the factory fog lights and traced them but i didnt cut the exact circle from the halo fog lights so the outer lip on the halo fog lights would catch the flashing and not pull through..i cut the circle out for the halo lights except for a two little square tabs located in line horizontally with the factory hanger holes which can be bent back and have holes drilled in them to screw the halo fog light brackets to..i also sanded the flashing to give it a brushed aluminum look which was very nice..let me know if you have questions or want pictures!!
  9. #9 Re: Brackets for Pilot fog lights......
    Banned
    Wichita Falls, Texas
    I just modified the brackets they come with in the box. Obviously does'nt adjust like the stockers though.
  10. #10 Re: Brackets for Pilot fog lights......
    I could not find the write up but am still looking for it ok..
    The Angel eyes are alot like those piolet lights though
    and if you take the braket that came with them you can mount that to the stock one to install something like this.. HTH
  11. #11 Re: Brackets for Pilot fog lights......
    Here is the info for you
    sorry took so long to find it hope it helps out..
    After buying them yesterday I installed them today.I used the wiring harness that came with the lights and I used the existing power to power up the relay using the purple wire of the OEM fog light wiring. I used the black one to ground the lights.
    Then I put the relay beside the fuse box under the hood and grounded it with the self tapping screw to secure the relay and attached the power wire to the top of the fuse box.
    Then I used the stock brackets and bolted the brackets that came with the lights to them
    Then I installed them into the bumper
    I used the white wire that came with the wiring harness to bring power to the lights and put everything back together. Here is the finished product. Those lights are very bright. I would say at least twice as bright as the OEM.
    Hope this will help some people that want to do this mod. It is not that hard to do just take the time to make proper connections and run the wires and tie them up with zip ties to hold them in place.
  12. #12 Re: Brackets for Pilot fog lights......
    ^i like the fogs. i hate that snow!
  13. #13 Re: Brackets for Pilot fog lights......
    SE Level Member BigG's Avatar
    St. Louis
  1. coil brackets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 02:53 PM
  2. Front Motor Mount Brackets..
    By GP2003GT in forum Visual/Body Modifications
    Last Post: 03-31-2008, 11:31 AM
  3. GMPP strut bars and donrome brackets
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 01-26-2008, 08:32 PM
