Thread: Need help installing halo headlights!!!
Results 1 to 18 of 18
  1. #1 Need help installing halo headlights!!!
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hey guys I am having some issues installing my halos, i have pretty much all the hardware installed in the headlight but the halos nor the projector will turn on, I do have some loose wires and a empty connector. Here are some pics
    thank you
  2. #2 Re: Need help installing halo headlights!!!
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Wow Thats a lot of spliced and linked wires. lol well it looks llike you have aa HID kit if so do you have a relay switch for them?
  3. #3 Re: Need help installing halo headlights!!!
    Round lake, IL
    I don't see a relay switch no
    I got all the lights to work minus the high beams and the rings themselves I want them working the most
  4. #4 Re: Need help installing halo headlights!!!
    Buena Park Ca
    Are these the led rings or the ccfl?
    Also is the high beam the hid or low?
  5. #5 Re: Need help installing halo headlights!!!
    Round lake, IL
    I think they are LED, and its the low beam, the projectors are hid
  6. #6 Re: Need help installing halo headlights!!!
    Buena Park Ca
    That's how I have my leds hooked up the thin white wire is the positive and blacks are negative they hook up to my turn signal bulb for day time running lights.
  7. #7 Re: Need help installing halo headlights!!!
    Antioch, IL
    what a hack wire job holy crap, boggled my mind to help ha
    2009 Challenger SRT8
    Expert at being gay.
  8. #8 Re: Need help installing halo headlights!!!
    Round lake, IL
    I have a baby blue and a black wire that are cut from the power source and the black and red wires are coming from the halos themselves
  9. #9 Re: Need help installing halo headlights!!!
    Buena Park Ca
    The very thin black and red wires at the bottom of the housing go to the turn signal bulb not you're main power source for the halo lights.
    The baby blue wire that is spliced from the connection is the low beam power and black ground of course the red wire is for the high beam
  10. #10 Re: Need help installing halo headlights!!!
    Round lake, IL
    So connect the halo wires to the turn signal basically
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  11. #11 Re: Need help installing halo headlights!!!
    Buena Park Ca
    Yes just make sure it's the wire that doesn't make the turn signal blink or you will have blinking halos lol
  12. #12 Re: Need help installing halo headlights!!!
    Round lake, IL
    My corner and side marker both blink simultaneously
  13. #13 Re: Need help installing halo headlights!!!
    Buena Park Ca
    Yeah but there are 3 wires if I'm not mistaken on the blinker bulb, one steady power one ground and one power wire that makes it blink.all you need to do is tap into the one that doesn't blink.
  14. #14 Re: Need help installing halo headlights!!!
    Buena Park Ca
    Went to go take a quick shot of the plug. And as you can see there is three if I'm not mistaken it should be the brown wire you need to tap for positive and black is negative
  15. #15 Re: Need help installing halo headlights!!!
    Antioch, IL
    Quote Originally Posted by deadsnake View Post
    thats normal
  16. #16 Re: Need help installing halo headlights!!!
    Round lake, IL
    Ok il give it a whirl thank you
  17. #17 Re: Need help installing halo headlights!!!
    Round lake, IL
    Thanks for the help GTP89 they are working
  18. #18 Re: Need help installing halo headlights!!!
    Buena Park Ca
    No problem glad to know it came out well and is running fine now..
  1. Halo Headlights. Funky problem when installing.
    By kking89 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2012, 06:42 PM
  2. Headlights are better after installing new struts
    By Lvgrandprix2003 in forum General Tech Discussion
    Last Post: 08-18-2010, 11:21 AM
