Thread: Clearing tails?
Results 1 to 20 of 24
  1. #1 Clearing tails?
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Hey everyone.
    I saw a grand prix on the weekend with the inside pieces of the tail lights removed so you can see the bulbs inside. I thought it looked pretty good. I found a pic of one car on this site that had done the same. Does anyone have any info or tips on doing this? I did it with a spare set of lights I had from my sunbird a year or two ago, but don't want to risk breaking my gp ones since I have no back-ups. Any info or tips would be appreciated.
    Thanks!
    Josh
  2. #2 Re: Clearing tails?
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    I think your referring to the clear lights with the chrome on the inside, if so here's a link to some on eBay.
    eBay Motors: 97-03 PONTIAC GRAND PRIX CARBON ALTEZZA EURO TAIL LIGHT (item 280265502786 end time Sep-16-08 17:53:57 PDT)
    eBay Motors: 97-03 PONTIAC GRAND PRIX CHROME ALTEZZA EURO TAIL LIGHT (item 310082755538 end time Sep-17-08 18:26:13 PDT)
    If not please clarify what your looking for please .
    *sig is too tall*
  3. #3 Re: Clearing tails?
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by Dboy23 View Post
    Nah, sounds like he's asking about the clear stock tail light mod.
    Let me see if I can find the write-up for you real quick.
  4. #4 Re: Clearing tails?
    Banned
    Here is a good page to check out.
    ClubGP Message Forum- Clear Tail Light Mod Information
  5. #5 Re: Clearing tails?
    Feb 2008
    Kansas
    i think i may try this over winter. the only thing that concerns me is hyperflash. i dont even know what that is...i assume it goes crazy when you hit the brakes? i read somewhere you need a resistor of some sort
  6. #6 Re: Clearing tails?
    Banned
    Quote Originally Posted by mwalk00gtp View Post
    No, hyper flash is just when you use your turn signal it'll blink quicker than it's suppose too.
  7. #7 Re: Clearing tails?
    May 2008
    Ontario
    On my sunbird I just heated the tails up and then pulled the lenses apart from the backing and then removed the inner pieces. I figured this would be done the same way instead of needing a dremel and cutting it apart. I think I will have to get a spare set and try iy out on those incase something doesn't work out well, haha. Thanks!
  8. #8 Re: Clearing tails?
    GT Level Member black98gt's Avatar
    Rochester NY
    Are you talkin about my style? The red inserts are just taken out.
  9. #9 Re: Clearing tails?
    ^hmm........
    how is the light output on those? seems like it'd blind the person behind u!
  10. #10 Re: Clearing tails?
    Rochester NY
    Its fine, got pulled over by a dick cop for having them like that but no problems since.
  11. #11 Re: Clearing tails?
    got more pics? perhaps some at night?
  12. #12 Re: Clearing tails?
    Aug 2008
    Michigan
    Quote Originally Posted by black98gt View Post
    Yeah it's defiantly a ticket for those.
    *sig is too tall*
  13. #13 Re: Clearing tails?
    Apr 2008
    Chillin at the Beach , VA
    Hyperflash is like what StreetWolf was saying. It is your turn signal flashing faster than normal. This is the case with running LED bulbs. The LED's don't draw as much power, so your car assumes you have a burnt out bulb which causes it to flash faster. This is to let you know that you have a bulb out so you can change it. Most companys that you buy your LED's from have a box(can't remember the exact name of it) that hooks inline to keep this from happening.
  14. #14 Re: Clearing tails?
    Rochester NY
    Quote Originally Posted by boosting98 View Post
    I can take pics tonite, dont have any right now of nite time. I have stock red bulbs in mine, so it wont be as bright as it would be with LED's
  15. #15 Re: Clearing tails?
    GT Level Member Preotic's Avatar
    Missoula, MT
    You don't have to cut the taillight up to clear it. You take a long screwdrive, hammer, long needle nose pliers(not absolutely necessary) and a set of dykes.
    You take the long screwdriver and insert it in the holes for the bulbs. You smack it good with the hammer and break the red lense(it's roughly an inch away from the clear lense right by the bulb location). The first smack seems like your gonna break through the lense and break the outer lense, there is room behind the red lense. After you break it continue breaking the lense with the screwdrive and hammer. Then turn the light upside down and use the needle nose to grab pieces of the lense and cut the pieces with the dykes to get them small enough to fall through the hole. I did it this way. I don't have any pics because my tails were tinted when i cleared them. I do however have this pic of the lense pieces.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  16. #16 Re: Clearing tails?
    Aug 2008
    Michigan
    Quote Originally Posted by BADAZGTP View Post
    Yeah for my rear LED lights each one had a small beige box with 3m tape on the back for me to stick on to something, I'm guessing that's what it's for, I can snap a pic if anyone is curious to see it.
    *sig is too tall*
  17. #17 Re: Clearing tails?
    May 2008
    Ontario
    Yes, this is exactlly what I am talking about. If you do have more pics that would be awesome!
  18. #18 Re: Clearing tails?
    Apr 2008
    Yeah, that's what I was talking about. Tricks the car into thinking the right amount of voltage is being pulled.
  19. #19 Re: Clearing tails?
    Aug 2008
    Michigan
    I was wondering what it was for because it didn't look like a battery pack to me lol.
    *sig is too tall*
  20. #20 Re: Clearing tails?
    Apr 2008
    That's why LED's are suppose to last a lot longer because of the low voltage they pull. They don't burn out as easy.
  1. Studies Say Clearing Land for Biofuels Will Aid Warming
    By GeddyLee in forum Off Topic Discussion
    Last Post: 02-11-2008, 02:28 AM
