Thread: Auto Dimming HID lights
Results 1 to 15 of 15
  1. #1 Auto Dimming HID lights
    SE Level Member Storm Smith's Avatar
    Mar 2012
    Arkansas
    So I have a 2000 Pontiac Grand Prix GT that has auto dimming lights so that during the day time they stay on but at a dimmed setting. When nights falls the interior nights lights come on and the headlights become brighter. I was thinking about putting some HIDs in the headlights. Will the HIDs auto dim and auto brighten like the regular lights?
  2. #2 Re: Auto Dimming HID lights
    The DRL's will ruin the hids.
    You will have to pull the DRL fuse and turn your lights on by hand when it becomes dark.
  3. #3 Re: Auto Dimming HID lights
    Mar 2012
    Arkansas
    Really? I really like that feature but if its going to ruin the HIDs then I guess I will pull the fuse. I also plan on getting some Halos to go with them.
  4. #4 Re: Auto Dimming HID lights
    Because the bulbs run on lower power during the day in a short time it will fry the ballast because its meant to always run at full power.
    So when i got my hid's in my 00 gtp, i pulled the DRL fuse and never looked back.
  5. #5 Re: Auto Dimming HID lights
    Mar 2012
    Arkansas
    Okay thank you. I think I might actually put in some Spyder CCFL Projector headlights since I hear good things about CCFL.
  6. #6 Re: Auto Dimming HID lights
    May 2011
    wisconsin
    You can keep your automatic lights but disable the drl...
  7. #7 Re: Auto Dimming HID lights
    Donating Users crock's Avatar
    Traverse City, Michigan
    Just take the module out like I did.
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  8. #8 Re: Auto Dimming HID lights
    Dec 2008
    Lawndale, CA
    Just pull the connector from the heatsink behind the little access panel on the drivers side dash. That will disable the DRL's but keep your autolights.
    GTP Level Member apierce1289's Avatar
    United States
    True, but its an easy fix. When you open the drivers side door you'll see a plastic panel. Pull off the little plastic door and you will see a heat sink with a wire plugged into it. Unplug the wire by pushing down the plastic clip with a flat screw driver. That's your DRL module, lights will still automatically come on at night ;-)
    Sent from my XT912 using Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  10. #10 Re: Auto Dimming HID lights
    Bunnell, FL
    or just run a relay kit like you're supposed to
    then the argument will become how are the bulbs getting low power if it pulls straight from the battery
    I'm a Sex Offender
  11. #11 Re: Auto Dimming HID lights
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by z3r0 View Post
    THATS A DAM GOOD POINT!!!!... I never really thought about that.... But that wont help with the keyless entry flash problem though will it????
    2011 F-150 Yote powered
  12. #12 Re: Auto Dimming HID lights
    Bunnell, FL
    you mean the one you can disable and switch to either completely off or the horn?
    I'm a Sex Offender
    Mar 2012
    Centerville, OH
    Does anyone know where the DRL's plug is located on a 04 GP GT. I have looked behind the panel on the drivers side and I have 3 different plug, so if that is the correct location which plug do I need to unplug? ImageUploadedByTapatalk1337096567.968548.jpg
  14. #14 Re: Auto Dimming HID lights
    Quincy, Mass
    you guys seriously need to start using the search bar or at least brows through the how tos, this was on page 6 i think
    http://www.grandprixforums.net/elimi...rix-22405.html
    No more GP 04 Impala SS Indy:
    Mar 2012
    Centerville, OH
    Quote Originally Posted by Swiggles View Post
    Didn't want to cut any wires. Was hoping someone knew of a plug or fuse to pull. My relay harness has gone bad and I have a new one on the way but in the mean time I was hoping to unplug something that I would be able to telling when the new harness came in.
  1. Auto dimming mirror
    By grandprixxx94 in forum General Grand Prix Discussion
    Last Post: 02-25-2012, 04:13 PM
  2. auto dimming mirror
    By tdm571 in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2011, 06:25 AM
  3. Auto Dimming mirror replacement
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2010, 03:20 PM
