Thread: Roof Rails
Results 1 to 19 of 19
  1. #1 Roof Rails
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    I had just recently bought a set of roof rails and was just wondering what you would recomend installing them with without screwing them in? and if its better how would you go about screwing them in?
    Ohio
    I used double sided 3m tape and ge clear silicone.
  3. #3 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    are they stuck on pretty good? i dont want someone to be able to run by and swipe them or they fall off when doing racecar stuff
    Ohio
    Dude i can grab them and try to pull them off while rocking the whole car side to side in the process haha
  5. #5 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    did you use the silicone on both sides of the tape?
    Ohio
    Yep.. Don't use a fat bead though haha cuz it will push out and that stuff smears and makes a mess haha so just a 1/16th bead down each side and those puppies will never come off haha
  7. #7 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    okay, ill do the bead on the 3m tape and put that on the rail and put a bead on the car then stick the rail on? and could i do all this in the cold (Wisconsin)
    Ohio
    No don't put the bead on the tape and rail. Stick the tape to the rails and make sure it's on firmly. Then on both sides of each roof channel, do a small bead down each side. Then stick the rails on and apply pressure evenly down each one.
  9. #9 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    okay, thanks man
  10. #10 Re: Roof Rails
    if you wanted to make sure no one ever stole them, you can pop a few screws in from the inside of the car, but this requires you taking off the head liner to do it.
    if i were to get another set i would do this. even though they are hard to rip off, you can still do it which is the main point.
  11. #11 Re: Roof Rails
    Donating User Odi's Avatar
    Chicago South Suburbs
    who the hell would steal roof rails? 3m double sided clear tape (that gel like) is stupid strong. pc modders use it to stick acrylic windows for the side panel.
  12. #12 Re: Roof Rails
    the regular black 3M double sided tape that is holding my lip spoiler to my trunk will rip paint off with it if you pull it off. it took me a half hour to take it off even using a heat gun.
    once it's on there, it's pretty well stuck for good.
  13. #13 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    okay good, and someone whos a theif and knows what they are... we have had a few thefts in wisconsin recently....
  14. #14 Re: Roof Rails
    exactly why if i were to do it again i would screw them into the roof so they would never come off.
    also, some of them dont sit completely flush anymore so the screws would help to pull them into the recesses.
  15. #15 Re: Roof Rails
    new britain, ct
    i personally know someone who has stolen a set of roof rails. not cool. but it can be done.
    07 Black GXP.
  16. #16 Re: Roof Rails
    Out West
    Solution: Forget roof rails.
    Whine with your Cheese?
  17. #17 Re: Roof Rails
    i would really like to screw them down but pulling the headliner is such a pita, it takes a 20 glueing job and turns it in to a day and plus theres a greater chance of messing them up idk if thats worth it,
    but if your not trying to just throw them on real quick and want to make a day of it then defiantly screw them down
    SMGPFC Member #10
  18. #18 Re: Roof Rails
    GT Level Member MRANGRYGTP's Avatar
    Niagara, Ontario, Canada
    GE Silicone FTW and yes, they do get stolen...
    2009 Holden Commodore SSV Redline Replica - 2009 BMW 328I M Sport - 1992 GTA Trans Am - Traded: 2004 GTP COMP G "Regenesis"
  19. #19 Re: Roof Rails
    Oct 2011
    Kenosha, WI
    roof rails = sex. i bet if you had them youd say otherwise
  1. Roof Rails
    By Biohazed in forum Visual/Body Modifications
    Last Post: 03-15-2011, 11:34 PM
  2. Roof Rails
    By csssaint12 in forum Visual/Body Modifications
    Last Post: 01-26-2011, 10:55 AM
