Thread: My cheap and easy solution for projector headlight bounce
Results 1 to 5 of 5
  1. #1 My cheap and easy solution for projector headlight bounce
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I love my projectors eversince I got them. They look great at day and even better at night. The light beam is 10X better than the stock lights and the halos look great also paired with LED bubls in the fog lamps.
    The problem is the infamous bounce. First here's a picture of my projectors:
    front
    rear:
    Now the problems is that they only hang from the two screws at the top and they have no support for the bottom part of the whole housing making it bounce up and down.
    At first I used weather strip, I put it in between the lower part of the housing and the fascia, but the problem is that the weather strip is too soft and it wears off over time and becomes thinner and the fascia is also flexible and will give in under vibration.
    The solution that I came up with is simple, just to get the housing to press against something more firm, in this case the chassis and I used rubber strips:
    The housing of the projector is the one closest to the chasis and it's also the heaviest part of the whole assembly. So what I did for now is just use electrical tape to hold the rubber strips behind the housings corner. I used enough until the housing rested firmly over them and the chassis:
    When you screw them back together, the housing will press against the strips and the chassis and will no longer bounce. You will notice it right away as when you try to move them with your hand they will be way more firm.
    I just did this today I still need to try it at night and maybe find a better way to hold the strips in place, but it will probably not be necessary as they are held together with the housing.
    I'm not sure if anything like this has been posted before in which case I didn't find it. The housing for spyder projectors seem to be different, but I don't have one to try it.
  2. #2 Re: My cheap and easy solution for projector headlight bounce
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Just finally fixed mine by looking at another thread. The best solution I have found is get some Styrofoam about say 2 inches thick and about 4 to 6 inches long and stick the piece between the metal on the bumper and the bumper cover just below the headlights. You may need to slightly bend the mounting on the frame of the car where the lights attach to but that will definitely fix any problem with bouncing. You can even use a piece of wood to do it also like say a 2 by 4 but I wouldn't recommend that because of it getting wet
  3. #3 Re: My cheap and easy solution for projector headlight bounce
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    smitz can you get some pictures of what you did? OP's pictures don't work.
  4. #4 Re: My cheap and easy solution for projector headlight bounce
    Dec 2012
    Hawai'i
    Hmm thiswould also fix the gap that some gp's have between the light a bumper cover. What about the gap above the grill between the bumper and hood? Is this a bumper cover fitmit issue you can adjust? I'd also like to see the pics that aren't working
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  5. #5 Re: My cheap and easy solution for projector headlight bounce
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    I just bought these and I know I'm gonna have a issue the old owner crashed and messed up the light and head light bracket I had a shop install a new one but I think they installed it a little off not crazy but it matters.. I have a idea to keep it in place I was going to spray some expandable insulation under the headlight and it should hold it pretty good not a crazy amount in case I need to take one off.. We shall see! Any comments?
  1. 2004+ Headlight Bounce Kit?
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 06-29-2013, 10:30 PM
  2. Annoying headlight bounce
    By GTLGDP in forum General Tech Discussion
    Last Post: 02-08-2013, 02:27 PM
  3. What Projector Headlight to get for Xmas?
    By buickman104 in forum Visual/Body Modifications
    Last Post: 12-04-2011, 04:03 PM
  4. OEM style headlight bounce
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-02-2011, 12:31 PM
  5. projector headlight question
    By superv6 in forum General Tech Discussion
    Last Post: 08-06-2009, 01:41 AM
