Thread: Fog lights coming on when i step on the brakes?
Results 1 to 6 of 6
  1. #1 Fog lights coming on when i step on the brakes?
    SE Level Member KadenGT's Avatar
    Jul 2011
    wisconsin
    i have after market Fog lights connected into my stock harness using a quick connect which has a plastic tubing over it and thats sealed shut with electrical tape. and i recent installed LED bulbs into my taillights which i do have the rear side marker as an LED also, it has the sequential tail light mod listed on here. but whenever i step on my brakes my fogs come on not every time only when i first start braking then my digital climate control goes blank and the gear indicator in the gauge cluster dims also then i let off the brakes and it goes back to normal but then the digital climate control also flickers when i use my turn signals and it only started this when i put in the LEDs for my brake lights. so i am thinking there is something up with bulbs or the wiring for the mod needs to undone and the wire needs to be soldered with heat shrink put over them. I am just curious as to why that would make my fog lights come on.. and if you guys think its the wiring of the bulbs. i also had the battery tested at work with a systems test. and my battery needs to be replaced could that be another factor? i wouldn't think LEDs would draw that much current they are all 12V bulbs from GPThunder so just some input would be nice..sorry for all the grammatical errors in this.
  2. #2 Re: Fog lights coming on when i step on the brakes?
    Nov 2008
    Waterloo, Iowa
    brakelight mod is buggerish. undo it. I did mine and it only created odd problems.
  3. #3 Re: Fog lights coming on when i step on the brakes?
    Jul 2010
    Coquitlam,BC,Canada
    Being that the problem started with the install of the LED bulbs, I would guess that they are backfeeding. Sounds like your "stop light" circuit is backfeeding to the "park light" circuit, which can go everywhere. Try a diode on the "park light" wire at each tail light socket.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Fog lights coming on when i step on the brakes?
    Jul 2011
    wisconsin
    Quote Originally Posted by Bronco Boy View Post
    Is there a certain diode should get?
  5. #5 Re: Fog lights coming on when i step on the brakes?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by KadenGT View Post
    I used 1N4006 on mine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Fog lights coming on when i step on the brakes?
    Bunnell, FL
    i'm gonna say its the sequential tails
    as backinblack himself reports problems like this especially with digital climate
    I'm a Sex Offender
  1. Any DIY Step By Step to Change spark plugs??
    By Importz in forum General Tech Discussion
    Last Post: 08-02-2012, 09:05 PM
  2. ABS ingauging when coming to normal stop - no lights on
    By albow77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 08:33 PM
  3. fog lights not coming on
    By 03limitedgtp in forum Visual/Body Modifications
    Last Post: 01-01-2012, 01:56 PM
  4. No tail lights but brakes work just fine??
    By Strummin365 in forum General Tech Discussion
    Last Post: 09-02-2011, 10:36 PM
  5. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
