Thread: VHT Nightshade
Page 1 of 21 12311 ... LastLast
Results 1 to 20 of 405
  1. #1 VHT Nightshade
    Evansville, IN
    I read somewhere that you can buy VHT Nightshade to tint your tails. I have moisture in the drivers side and I want to tint instead of replace. I need to know where to get it. I thought someone said you can get it at Autozone, looked but didn't find it. I really don't want to buy it online, a store or paint supplier would be better for me. I am located in southern Indiana.
  2. #2 Re: VHT Nightshade
    Saraland Alabama
    only place I have seen it is online
  3. #3 Re: VHT Nightshade
    ^i'm w/ him.
  4. #4 Re: VHT Nightshade
    Donating Users
    W-S, NC
    If you go to Advance Auto or Autozone, they can order it for you. Takes 2 days to ship and costs roughly $12 a can. They wont advertise it on the shelf, but if you ask they can look it up. Just make sure you get someone who knows what you are talking about.
  5. #5 Re: VHT Nightshade
    SE Level Member gtman98's Avatar
    Aug 2008
    Phillipston, Massachusetts
    orielys has it in stock some times.
  6. #6 Re: VHT Nightshade
    Aug 2008
    KCMO
    the only bad thing about the VHT is that you have to do all the wet sanding and buffing and then clear coat them. i would recommend seeing what a local paint shop would charge you to do it for alot better result.
  7. #7 Re: VHT Nightshade
    SE Level Member chitownchevy's Avatar
    Chicago
    Most local ricer shops keep it on the shelf. It is easy to do and you can get good results,
  8. #8 Re: VHT Nightshade
    May 2008
    McHenry IL
    how man cans would it take just 1 right for both tails
  9. #9 Re: VHT Nightshade
    GXP Level Member ryangtp89's Avatar
    Maine
    One can will get both your tails as dark as you want them and still be enough left over. I was lucky enough and found vht at my local speed shop for 10 bucks. It's super easy to do, and make sure to get a can of clearcoat too.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  10. #10 Re: VHT Nightshade
    TDCRacing
    Guest
    Quote Originally Posted by ryangtp89 View Post
    You've been here on the forums a little while now...so you know now you have to post some pics right? LOL
  11. #11 Re: VHT Nightshade
    Maine
    Dude i haven't been able to find my usb cable forever soo i can't it sucks.
  12. #12 Re: VHT Nightshade
    TDCRacing
    Guest
  13. #13 Re: VHT Nightshade
    Maine
    OOOOH NOOOOOO!!!!! PLEASE DONT!!!!!!!!!! lol
  14. #14 Re: VHT Nightshade
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    VHT should only be referred to as VHT when its laid out like this
  15. #15 Re: VHT Nightshade
    Donating Users Warbeaver's Avatar
    St. Louis
    I used this stuff with great success tinting my tail lights for the first time. heres a write up without pics:
    Clean taillights
    get some 2000 grit sandpaper and a little bowl of water
    start by wetsanding the entire tail light. It will look very dull with a lot of fine scratches in it. it will turn a greyish white color.
    dry off all the water
    Apply a thin even coat of VHT over the tail light. Make sure its a very light coat and make sure your apply it evenly. do not hold can too close to the taillight because it will run. (If it does run, you can get by if you let it dry and then wetsand the spot)
    let this coat dry
    now wetsand again with the 2000 grit sandpaper
    Apply your second coat of VHT. This one can be a heavier coat than the first. This may be the last coat you will need depending on how dark you want your tail lights. For those of you who want them like mine, i did 3-4 coats. just repeat the process i explained.
    once you have your desired darkness, let it dry and DO NOT wetsand.
    Start applying your clear coats. I used Duplicolor auto clear coat. On these coats you just apply and let dry, apply and let dry. I did about 3-4 coats of clear. this is what protects the taillights and gives them more shine.
    once you finish, put in a safe spot and let dry 3 hours. I left mine in a garage with a fan going.
    once they are dry, take some car wax and polish them up. this will give them even more shine and protect them further.
    I would recommend staying with 2 coats of VHT because mine are impossible to see at daytime. at night they are fine and you can't really tell the difference.
  16. #16 Re: VHT Nightshade
    Donating Users
    W-S, NC
    ^^^Those tails look good! Nice job!
  17. #17 Re: VHT Nightshade
    Banned
    Now you need a sticky on how to remove nightshades when it goes bad!!!!
    Nightshades are for kids!!!
    Tint the damn things the right way...By a professional!!!
    http://www.flipscustomtails.com/forums/
  18. #18 Re: VHT Nightshade
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    Here is my VHT job. I got the bottom one pretty shiny. I got tips if anyone needs them. I wasn't satisfied with the bottom one, minor scratches in it, so i did them again, and the bottom picture was the result. Doesn't get much better than that!! No dimples, smooth as silk.
    You can find VHT at O'Reiley's
  19. #19 Re: VHT Nightshade
    Aug 2008
    Long Island, New York
    im lookin to do that too
  20. #20 Re: VHT Nightshade
    Donating Users
    W-S, NC
    Quote Originally Posted by Z28 View Post
    Some carry it and others dont....I havent seen much around here. I ve seen some people use Masters black trans. hobby paint. My tail lights were damaged and I went with the Master's red trans. paint and they have the all red look and are pretty smooth. I'll see if I can get some pics and post them. It's just different lol.
  1. spray VHT nightshade on headlights look decent or not?
    By fst in forum Visual/Body Modifications
    Last Post: 03-04-2008, 09:01 AM
  2. Effect Of NightShade On Light Output
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 02-08-2008, 08:36 PM
