Thread: HID Help? Anyone have a solution?
Results 1 to 11 of 11
  1. #1 HID Help? Anyone have a solution?
    May 2011
    wisconsin
    So I have a 2007 grand prix gt and I want to put hids in but I'm hearing a lot of things about the day time running light messing them up because they work on a lower amperage. Flickering and the lights turning off seem to be the main problems. I'm guessing the fog lights and high beams will be fine because those are either on or off but is there a way to turn off the "drl" so I dont have to deal with this problem? In the earlier prixs there was just a fuse to pull or a harness to unplug to get the "drl" to turn off but I've tried everything on my 07 prix but I failed. Anyone know anything so I can get my sexy hids and be a poon magnet?? <---dramatization
    Thank you very much for any and all help!
  2. #2 Re: HID Help? Anyone have a solution?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    get a relay harness is your best bet
  3. #3 Re: HID Help? Anyone have a solution?
    May 2011
    wisconsin
    Quote Originally Posted by csssaint12 View Post
    This does what and where do I get it?
  4. #4 Re: HID Help? Anyone have a solution?
    GTP Level Member
    Nov 2011
    Kansas
    My 08 you can turn the drls off by twisting the light switch ackwards toward auto... Just have to remember to do it all the time. My hids seem to have a vibrating look when sitting still, which may be flickering, idk.
  5. #5 Re: HID Help? Anyone have a solution?
    May 2011
    wisconsin
    Quote Originally Posted by develand View Post
    Yeah thats what I do now to turn my lights off but I heard that quick ons and offs are readily bad for hids and can burn out the ballasts. Thats why I'm looking for a way to make them not turn on at all untill the might time light come on or I manually turn them on
  6. #6 Re: HID Help? Anyone have a solution?
    GTP Level Member
    Nov 2011
    Kansas
    From what I have heard if you pull the DRL fuse, it also kills the Auto feature.
  7. #7 Re: HID Help? Anyone have a solution?
    May 2011
    wisconsin
    There isn't a drl fuse on my car. I've looked in my book and looked at both sets of fuses and there isn't anything for them
  8. #8 Re: HID Help? Anyone have a solution?
    Chilliwack BC
    i put a piece of tape over my photosensor on the dash...now headlights come on all the time when i start the car. you could always unhook the sensor on the dash...
  9. #9 Re: HID Help? Anyone have a solution?
    May 2011
    wisconsin
    Quote Originally Posted by Couch View Post
    Yeah I'm probably gunna just do that untill someone finds a wait to disable them
  10. #10 Re: HID Help? Anyone have a solution?
    Bunnell, FL
    get a relay harness for sure
    then the drl's should power the harness and give teh hid's full power
    I'm a Sex Offender
  11. #11 Re: HID Help? Anyone have a solution?
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    my 08 has the drl harness cuz they flickered twice. I have never had a problem but i did hv to cut n cross the two leads and do the same to my drl. Now, i have four headlights on high beams.
  1. Aux Input Solution
    By SNeitzel in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2016, 05:43 PM
  2. Better solution to a gasket?
    By corsagtp in forum General Tech Discussion
    Last Post: 03-21-2010, 08:26 PM
  3. A non welding solution
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 09-23-2009, 02:22 PM
  4. IAT solution
    Last Post: 02-12-2009, 10:11 PM
  5. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
