Thread: Morimoto Mini H1 4.1 heads & fogs projector retrofit
Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
  1. #41
    Ohio
    Are you using ****ty bulbs?
  2. #42 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jul 2008
    Tampa, FL
    looks great man. i wantz this.
  3. #43 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Topeka, KS
    Nice Pix!
  4. #44 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by szalajka05 View Post
    I just did a projector retrofit and I hate it. Light output kind sucks... Going back to stock housings and gunna blind everyone lol. At least I'll be able to see.
    Yeah you did something COMPLETELY wrong, because no one with a proper retrofit "hates" it. If you used the same ballasts and same brand bulbs, that alone should increase output because all the scattered light in stock housings is now focused on the road. If you used non-clear lens projectors from another car, THEN maybe your output would suck, but if you used the Morimoto Minis and the bulbs that came with... well you're doing something wrong, or you're insane.
    Btw, it has to be DARK for headlights to work. >_>
  5. #45 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Not a clue how retrofits suck? Something must be wrong
  6. #46 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    SE Level Member SlprGS's Avatar
    Greensboro, NC
    bump.. diggin' that setup.. I did my retrofit on my regal a few months ago. Light output is greater than stock setup but not as good because the lenses are a little hazy and I might have over tinted them so I'm waiting for my reimbursement from work and I'll redo them. BTW I used non-clear lenses from a mini cooper. I might just have to upgrade to the marimoto minis..
  7. #47 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    GTX Level Member colindunn's Avatar
    Aurora, IL
    im finally doing my fog light retrofit tonight.
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  8. #48 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jun 2014
    United States
    How did you get the fog housings open? I've heard heat doesn't do anything. If so, then what is the process???
  9. #49 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Heat doesn't work?
    Note pictures 2 and 3
    http://www.grandprixforums.net/threa...-08-Headlights
  10. #50 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jun 2014
    United States
    Quote Originally Posted by Drunkie View Post
    Heat doesn't work?
    How much heat?
    I had them in the oven at 275 or so for at least 10 minutes and I can't get the lens to budge. I feel like if I pry any harder I am going to start breaking the lens.
  11. #51 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Those were aftermarket, OEM uses a much tougher glue. 225* is the most I would do and give it a little longer
  12. #52 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    It takes a lot of patience and finesse to get them open.
  13. #53 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    This!
    04 Comp G.
  14. #54 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jun 2014
    United States
    The housings I bought are aftermarket, just got them in the mail today. I don't THINK they are OEM but who knows?
    So say 225*F for like 30 minutes? And just use a screwdriver around the edge and work it until it starts coming? Do you start at a clip?
  15. #55 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    keep your eye on it, it should only be 15-20 minutes.
  16. #56 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Remember you can always go back and heat them up more if needed so don't overdo it.
    04 Comp G.
  17. #57 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jun 2014
    United States
    I'm gonna keep the stupid questions going - what am I keeping an eye out for? Is there some telltale sign that they are "done" and ready to be pried apart?
  18. #58 Re: Morimoto Mini H1 4.1 heads & fogs projector retrofit
    Jun 2014
    United States
    Got them open. What a b!tch. scratched them up quite a bit too. I think these may have had OEM style glue as they didn't come apart with clear glue like the link above shows. I could probably get them apart without much scratching if I had to do it over again.
    I think what I am gonna do is heat them up and scrape all that OEM crap glue out of the housing and off the lens. Then I will use butyl when I seal them back up for a leak-free and easy to remove seal if I ever need to open them again.
  1. FX-R Headlights, Morimoto Matchbox Fogs
    By Confusingboat in forum Audio, Security & Visual Electronics
    Last Post: 06-04-2012, 11:36 PM
  2. Let there be LIGHT! (Morimoto projector retrofit)
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 02-09-2011, 11:03 PM
