dont know how many of you make it to the how-to/write ups so i thought id duplicate it here... (mods if this isnt ok, feel free to delete this, i just wanted as many people who feel they need/want this to see it - specially with tinted tails)
ok guys, after seeing a few local members pictures of their 4th brake light, and looking at my tinted tails everyday, i decided i needed a set of these for many reasons. there isnt much to explain the pictures say it all...
but if you have any questions feel free to ask...
and the kit is a universal "24 Red LED Strip (attaches with double sided tape)
First, remove the taillight (i choose to use the passenger side) by taking out the 2 screw style holders inside the trunk
Dont forget the third one behind the carpet
Next i tapped into the 3rd brake light for my source of power. others told me to use the taillight but that is a BAD IDEA!!! DO NOT USE THE TAILLIGHT. you can but its too much work. because you tap the high side of the bulb, which means when you brake it will work but it will also flash with the turn signal (on the side you tap) so just use the 3rd brake light.
I ran the wires inside the decklight and dropped it out outside of view and ran it behind the carpet for cleanliness...
Next i drilled 2 small holes in the car (one in the chassis and one in the bumper) just big enough for your wires to fit...
Next run the wires from the LED strip through the hold in the bumper and through the chassis hole also... i used silicone on the chassis hole to keep water out of the trunk.
Here shows where my wire came through from the whole in the chassis. it come through inside that channel.
A little joining of the wires and heatshrink and tape and your ready to finish up.
Little tape to hold the wires up temp till i figure another way to mount the wires...
This is the strip taped down to the bumper channel.
Lights working beautifully!
As you see here on my color you can kinda see the strip but it is really not noticeable during the day. i am actually going to paint the small "1/2 peice of the bumper to the sides black to make it blend better... and probably the top of the bumper between the tailights so it is as if there is one long black strip going across there (from taillight top to taillight top) I put one on my friend jose's black gp and it blends in smoothly...
