Thread: Vinyl installations
Results 1 to 12 of 12
  1. #1 Vinyl installations
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    I have a 2 foot by 2 foot vinyl for my back window ready to go on. However, Im not sure if i feel comfy installing somethig like that myself just because of the size. A small decal I would have no problem being confident I could get all the bubbles out and flat on the window. SO I was thinking of having it profesionally installed. Any advice? DO you think I should try it or wait?
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Vinyl installations
    Houston
    If you take a spray bottle with water and a lil bit of soap, you can keep the decal wet and prevent it from adhering as soon as it touches your window. Once you get it where you want it, use a credit card (or something similar) and squeegy out the bubbles
  3. #3 Re: Vinyl installations
    Jul 2010
    Michigan
    Hmm interesting tactics. Im half way in a rush due to moving next wednesday. Ive been waiting to hear back from a place that my buddy got his done at... with no response so Im half fed up at this point
    2005 GTP Grey
  4. #4 Re: Vinyl installations
  5. #5 Re: Vinyl installations
    MA
    interesting trick
    does that affect the life of the decal? good to do on a roof?
    SMGPFC Member #9
  6. #6 Re: Vinyl installations
    London Ont, Canada
    Reflective concepts advises against doing the soap trick for their reflective ones, their stock vinyls they say go nuts..
    What is this 2x2 vinyl of??
  7. #7 Re: Vinyl installations
    Houston
    Quote Originally Posted by SilvaMan61 View Post
    interesting trick
    Thats how I put the vinyl on my roof.
  8. #8 Re: Vinyl installations
    Tofu Delivery Boy Lsick7's Avatar
    MO
    I'll second that. The reflective ones are almost just like a sticker. They have an adhesive backing that can be ruined with soap and water. Regular vinyls however it is perfect for. I used that technique on my rear non reflective inlays, allows for repositioning and such.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  9. #9 Re: Vinyl installations
    Donating User Odi's Avatar
    Chicago South Suburbs
    always did the 1-3 drops (some say add more) of dish washer soap + water in a spray bottle. did this on non-reflective that are on my car. also did that on REFLECTIVE on my buddies car last season. No problems so far.
  10. #10 Re: Vinyl installations
    Jul 2010
    Michigan
    To answer it its the Decepticon symbol nice and big for my back window. Not an inlay. However, Im thinking about doing some inlays soo too :P
    2005 GTP Grey
  11. #11 Re: Vinyl installations
    Kansas
    Water with a few drops of baby oil as well works.
    When I did my big back window one a couple weeks ago, we measured like a mofo. Then took a sharpie and drew corner placeholders where the corners needed to be. Lay it down from on corner than work your way down. Probably a lot easier with two people doing it.
  12. #12 Re: Vinyl installations
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    If its not the one that gets ruined by alot of water and soap in my opinion just soak the crap out of that thing so that when it hits your roof you give your self plenty of time to get it situated the way you want it. Also once its on your roof spray the top of the vinyl so when your using a credit card or what ever you use to get the bubbles of water out its not dry and you rip the vinyl....ive ripped alot of tint making that dumb rushfull mistake where i dont wet it good enough and you go to squeegee it and it rips cause its too dry. Then work your way from the center out that way you start moving all the water and air bubbles twords the edges. And if all fails in getting them last little air bubbles out use a heat gun to get rid of them or find the smalles needle you can find and poke a small hole and get the air out that way. My rule for back windows on cars and if i would do a big piece of vinyl is ALWAYS have a friend back you up because your gonna just mess up the placement of it and its gonna be a million times harder to do.
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  1. vinyl application - milwaukee
    By Bio248 in forum Midwest
    Last Post: 05-04-2011, 12:27 AM
  2. Help me find this vinyl...
    Last Post: 03-23-2011, 10:45 PM
  3. Vinyl VS paint
    By slopez in forum Visual/Body Modifications
    Last Post: 12-31-2010, 01:46 AM
  4. Vinyl Top ?
    By Pontiac Warrior in forum Visual/Body Modifications
    Last Post: 12-06-2010, 12:02 AM
