Thread: new headliner
Results 1 to 20 of 30
  1. #1 new headliner
    SE Level Member NewBoost1997's Avatar
    Jul 2010
    Minnesota
    So, windows were down and rolling down the highway and i notice that the sag in my headliner is getting worse...sucks. looks like trailer trash. anyways i want to replace the fabric on it...
    i do have an aftermarket sunroof if that makes a difference. my car is a 97 gtp 2 door. any suggestions on how to do this? i know i can get it down, but getting it out is the problem...
    newboost
  2. #2 Re: new headliner
    Waukesha, WI
    i want to say it should fit through the door opening on an angle, if not yank the windsheild?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: new headliner
    Jul 2010
    Minnesota
    ive read somewhere else that you need to pull the windshield...but im not looking really to do that unless i have to hahaha
  4. #4 Re: new headliner
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by NewBoost1997 View Post
    I'm guessing but maybe pull the passenger side seat out to get the new one in?
  5. #5 Re: new headliner
    Jul 2010
    Minnesota
    I hope that works. I dont want to remove my windshield really. I mean I could bust up the old one but then the trouble is getting the new one in
  6. #6 Re: new headliner
    GTX Level Member Spencerad4's Avatar
    Apr 2011
    Royal Oak, Michigan
    I would think that if you pulled out the front seats you could get it in/out.. Worst case.. Just bull one the the doors off to get the new one in easier..
    Id think that would be less work the the windshield..
    "..Pure adrenaline attached to a license plate.."
    SMGPFC # 007
    Alpha Dog of the SMGPFC
  7. #7 Re: new headliner
    Waukesha, WI
    really? i would go windshield route, cut out with knife, clean, epoxy flange and glue in window
    RayRay
    92 Turbo miata
    02 lexus is300
  8. #8 Re: new headliner
    Kansas
    I think you guys are all crazy for taking out the windshield. Good luck getting it out without breaking it.... and that will be at least $200 to get a new one and install. Why not use some of this junk?
    3M Super 77 Multipurpose Spray Adhesive: strong-bonding, fast-drying glue that you just spray on. Think it up, glue it down!
    Get some clear plastic to lay over all of your interior, tape off parts, rip out factory cloth.... get new cloth... and spray that stuff on it and put it up. Boom... done... simple. They also make hi-strength 90 as well.
  9. #9 Re: new headliner
    London Ont, Canada
    yeah i dont get why take it out if its just sagging? just add some more adhesive problem solved?
  10. #10 Re: new headliner
    Bunnell, FL
    i'm interested in the aftermarket sunroof
    I'm a Sex Offender
  11. #11 Re: new headliner
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Can you pin it up with straight pins pushed in at a severe angle - almost parallel with the roof? It's not perfect, but will hold it up until you can repair or replace it. It's hardly noticable unless someone is really looking for it. I've done this on several older model cars/trucks.
  12. #12 Re: new headliner
    Feb 2010
    TN
    newboost
    Its really simple
    Remove; Sun visors, overhead console, Sunshade retainers, Dome lamp, sunroof trim lace, Coat hook, rail, lamp windshield side molding, upper quarter trim panels,
    Pull down on weather strip seal around doors
    There will be two retainers remove them
    There is a lot of Velcro material under there get a plastic wide blade putty knife slide it between to work it free once headliner is free work it out through the passenger side door. A quick note here taking out the passengers seat is not necessary, BUT it does make getting it out a LOT easier, If you remove all seats its even easier still
    Hope this helps
    Logan
  13. #13 Re: new headliner
    Kansas
    Quote Originally Posted by z3r0 View Post
    THIS!!!
    I noticed that too.
  14. #14 Re: new headliner
    from what i've seen on tv shows, you will need to remove the foam padding from the headliner, then you can use rubber cement from a spray can on both the head liner and the new headliner material of your choice, just leave it 2 inches wider than the headliner and fold the extra around the to the underside of the headliner, makes a better looking termination around the sides. and use what ever material you like, you can pick up a lot of good stuff from sewing stores that sell fabric and what not by the yard for cheap.
    a little tip, lay the head liner out with the new material laying over it, get it where you want it, then fold the new liner 1/2 way back, and spray 1/2 first, let it dry then push the liner over the sprayed area, press it in, then do the other 1/2, that way it wont move on you.
  15. #15 Re: new headliner
    Feb 2010
    TN
    newboost
    oh yeah and check ebay for the headliner material you can get it for about $12.00
  16. #16 Re: new headliner
    The Boss Iceman6669's Avatar
    Jun 2011
    Sub'd....Have to rip mine apart to fix my aftermarket sunroof.....
  17. #17 Re: new headliner
    Ocala, FL
    Saw this for a bonneville a while back:
    View topic - How To: 2000+ Headliner/Sunshade Replacement : PontiacBonnevilleClub.com
    Very similar so should help.
  18. #18 Re: new headliner
    Waukesha, WI
    ive taken a couple windsheilds out with out breaking them, just take your time
    RayRay
    92 Turbo miata
    02 lexus is300
  19. #19 Re: new headliner
    And when you re-do the entire interior...might as well make it nice, right?
  20. #20 Re: new headliner
    Odessa, MO
    Quote Originally Posted by redlinepontiac View Post
    Yeah, it sounds so easy. LMAO
  1. How to remove '04+ headliner?
    By Motown in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 01:34 PM
  2. headliner
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 06-10-2010, 03:01 PM
  3. Cleaning headliner
    By KMAN in forum Shops and Community Heroes
    Last Post: 03-15-2010, 10:30 PM
  4. headliner
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 03:31 AM
  5. Headliner?
    By JESSEGOTTA GP GT in forum Visual/Body Modifications
    Last Post: 02-07-2010, 03:13 AM
