Thread: 2000 GTP info center in a 2000 GT?
Results 1 to 8 of 8
  1. #1 2000 GTP info center in a 2000 GT?
    SE Level Member ZachBW55's Avatar
    Ramsey MN
    Hi I was wondering if the information center out of a 2000 GTP would work in a 2000 GT? Will it just plug in? and will it be able to tell me my millage or will it take some computer stuff?
  2. #2 Re: 2000 GTP info center in a 2000 GT?
    GT Level Member Tea Time's Avatar
    New Brunswick
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: 2000 GTP info center in a 2000 GT?
    SE Level Member av91's Avatar
    Flint, MI
    Yes, but you would want one from a GT, not a GTP, because there is a difference between the two in the button on the right that disables/enables traction control. The GT one should say 'TRAC', while a GTP says 'TCS'. I heard if you get the wrong one, it will still work, but the traction control light will be on while the system is off and vice-versa. You can get any 98-03 GT one and have it work. (Mine is from a 98)
    Yes it shows fuel economy, if that's what you meant. All it requires is the wire to the connector under the dash (assuming your car doesn't have the harness hiding behind the old DIC). Just follow the link posted above, it has everything you need.
    Andrew
    2003 Grand Prix GT
  4. #4 Re: 2000 GTP info center in a 2000 GT?
    Ramsey MN
    Thanks guys
  5. #5 Re: 2000 GTP info center in a 2000 GT?
    Dec 2008
    Lawndale, CA
    You can rewire the GTP TCS light to work the same as the GT TRAC light.
  6. #6 Re: 2000 GTP info center in a 2000 GT?
    Quincy, Mass
    x2 that its pretty simple. and the boost wont show up either.
    No more GP 04 Impala SS Indy:
  7. #7 Re: 2000 GTP info center in a 2000 GT?
    Ramsey MN
    I will be putting pillar gauges in after my top swap so I don't want the boost meter. I'll go with a gt
  8. #8 Re: 2000 GTP info center in a 2000 GT?
    Dec 2008
    Lawndale, CA
    The boost will only show up if you top swap regardless if it is a GTP or GT DIC.
  1. need info on 2002 mustang vs 2000 grand prix gt
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-09-2009, 05:12 PM
  2. info center problems and maybe KR?
    By projectGTP in forum General Tech Discussion
    Last Post: 12-19-2008, 12:40 PM
