should i sell my projectors and make my own creation of led strip/morimoto retro fits in black housings??
I say go for it. Money and patience permitting..
I'd love to..but I lack those 2 qualities.....
Plus, you could do a write-up, and people would love you forever.
so morimoto projectors are much better output wise than what i have now?
To the point where they aren't even comparable. If you've got hids in your projectors now, the morimotos will make it look like you've had halogens the whole time. Plus the beam is MUCH wider and more uniform.
as a comparison, the first beam pattern is from the aftermarket G1, which is gonna be about the same to slightly better in beam pattern and brightness as the halos you have now.
and the morimotos
I know this comparison isn't perfect, but it's fairly close. Those halos have really cheap projectors in them which aren't designed for hids, so the output is acceptable at best.
im thinking the fxr would be good. the beam is so wide in the pics
which shroud looks better the transparent graphite or chrome gattling. wow they even have a ccfl halo ring option here : http://www.theretrofitsource.com/pro...roducts_id=227
