Thread: Two Morimoto projectors one cup...uh...I mean headlight...headlight
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 240
  1. #61 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    So you used aftermarket headlights and put in quality projectors. That's correct right?
    Yeah. My first set up was a set of OEM used headlights off of ebay and this current set is an aftermarket rip-off of OEM headlights. The main difference that I've noticed between OEM and the aftermarket OEM rip-offs is the adhesive. OEM uses an adhesive that is flaky and kind of peels off and the aftermarket ones uses a stickier, roofing tar-like adhesive.
  2. #62 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    Quote Originally Posted by RedDawnGXP View Post
    Really the black oem style housings I've been using were of the flaky type adhesive you talk about. I had no problems peeling the lenses at 185* for 10 minutes in the oven. Not messy at all, I use windshield adheasive to reseal to make sure there's no condensation getting into the housings I do for people.
  3. #63 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Quote Originally Posted by cleangtp View Post
    Yeah OEM has the flaky adhesive, aftermarkets are the gooey adhesive.
    I personally use a heat gun and do top to bottom. Just a personal preference, oven works great too though.
  4. #64 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Topeka, KS
    So do you plan on manufacturing the linked 97-03 Morimoto equipped housing cause that would be sweet! I'd love to do Projectors but I dislike all the issues and the single piece design that the company's that did all our projectors have.
  5. #65 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    Quote Originally Posted by rynoman03 View Post
    Don't know about mfg them but I know how to do them,
  6. #66 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Never Never Land
    say i was to replace the projectors in my spyders with quality projectors...probably morimotos...i wouldnt have to worry about melting stuff if i used 55Watt bulbs would I?
  7. #67 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Never Never Land
    Quote Originally Posted by BoostJunki3 View Post
    should i sell my ccfl projectors and retrofit some black housings???hmmmm
    What you SHOULD do is tell me how you mounted your projector fogs. LOL
  8. #68 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    So I'm gonna paint the reflectors black but what color should I rock with the shrouds? I could rip off Drunkie and paint em red (which would match the car), paint them black or leave em silver. What do you guys think?
    You can do red...I no longer have red
  9. #69 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Quote Originally Posted by DrunkietheBear View Post
    ?? C'mon, don't tell me you're at it AGAIN??
  10. #70 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Things are happening.
  11. #71 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Never Never Land
    ohh that looks uh-may-zing
  12. #72 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    That looks freakin nice, how did you manage to keep the lense so freakin clean
    Must be nice to have that much room to work with and not have to trim your shrouds to get the projectors into the housing. (97-03) housings suck for retrofits!
  13. #73 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Thanks. I used latex gloves. No glove no love...err...clean lens. I learned my lesson from my last retro lol.
    I did have to trim the shroud in the highbeam side a bit but nothing like on a 97-03 retro.
  14. #74 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    I love the looks of the Dual projector housings. The one's that dz sells are crap but i think they look great. I would love to build my own set simmilar to the ones shown above with good projectors. Is there any way to get a detailed list of parts needed and what was done to make them correct. I would like to do the halo eyes along with led's but do not have to. Just love the look. If there is another thread with this info just tell me where.
  15. #75 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    I use gloves also but still managed to pick them up a few times without them on
    The threads on the back of projector still don't protrude long enough to get the lock washer down far enough to have the bulb holder flush. Is it this way on the retro you have? It takes some major dremel work to get these projectors not to have cross beam, then you have problems locking them down squarely. I think the 04-08's are much easier to retro and adjust. After looking at your retro you're making me want to throw mine in the trash.
  16. #76 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    I was REAL careful LOL.
    There isn't enough room in these headlights to mount them to the reflector with the threads and locknuts because they hit the lens so I had to do plenty of Dremmeling.
    I put the rubber boots on the back but I need to seal them with some Permatex a la:
    There is a drip edge on the frame of the car that drains right on to the back of the lowbeam:
    You can see the channel above the cut out plastic on the left. It literally drains right on top of the headlight.
  17. #77 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Quote Originally Posted by zx7r4u2nv View Post
    I'll try to do a quick list of parts of the top of my head:
    1) Spare set of headlights
    2) Morimoto H1's, 1 pair for a single set up, 2 pairs for a quad set up
    3) 3/4" or 1" machine screws and lock nuts, I think I used a 10/32
    4) Gatling shrouds, I believe they are "mini" Gatlings
    5) 2 or 4 HID ballasts depending on single or quad set up
    6) 1 or 2 relay harness(es) depending on single or quad
    7) Silicone sealant for back of headlights (I recommend Permatex black silicone adhesive/sealant)
    8) High heat black paint for reflector (If you wish to paint it)
    9) Dremmel with diamond tip cutting bits. (You don't need the diamond tip but it sure makes things go quicker. Thanks to Drunkie for the recommendation)
    10) Latex gloves for smear reduction.
    11) I personally use a heat gun, makes it easier in my opinion since I can control the heat and it helps stop the lens adhesive from "spider-webbing" and making a huge mess. If you don't have a heat gun a good old fashioned convection oven does the trick.
    12) Silicone adhesive or JB Weld to attach shrouds to the projectors. I personally use silicone adhesive because it doesn't become brittle and it isn't impossible to remove should I wish to change shrouds.
    13) Time.
    14) Patience. Don't rush anything and keep in mind you may find yourself chasing your tail having to touch up paint here and there and adjust the projectors until you get them right.
    I'm sure I am forgetting something. I'll eventually do a full write up and request (and require) that cleangtp and Drunkie chime in.
  18. #78 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    I know one part that makes it a ton easier on resealing the lenses. No more using silicone sealant for me.
    OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc
    Put this in your channel/grove before putting lense on. Push lens on, stick in oven at 275* for 7 minutes. Take out of oven and clamp down or keep constant pressure on lense til it cools. Cut excess off with razor blade.
  19. #79 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    Damn, wish I woulda gotten some of that for my last retro. OEM headlight adhesive sucks lol. These aftermarket ones have the adhesive like the link that you sent me and they very liberally applied it LOL. After all is said and done and I am confident that I don't need to tear em apart I always lay a bead of sealent along the top of the lens anyway. It isn't all that necessary with these headlights but it doesn't hurt.
  20. #80 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Banned
    Mansfield, Ohio
    Yes after I seal them up I also go around the complete headlight with a silicone bead. I press it down into the gap until I see no gap then wipe clean. Go thru a lot of paper towels but it guarantees no water. I haven't gotten any moisture in mine to this date.
  1. DRL headlight help..
    By singularity in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2009, 02:29 AM
  2. Headlight
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 03-20-2009, 09:49 PM
