Xogiox already did the write up.
Original Thread
I'm just posting pics. Make no mistake, these little bastards are 100x better than stock housings. The cutoff is a tiny bit fuzzy, but I can fix that by adjusting the bulb a bit. The high beam mode is phenomenal. I'll replace my black corners with the clear ones when I get around to finding them...
Unsurprisingly, the beams do cross a little just like every other projector assembly for the GP out there. I think that this is because the plane in which the original 9007 bulbs sit on are not parallel with each other to being with. The assumption is that the bulbs are on the same axis as the light output, but in reality they are not. The simple fix for me is to sand and shim on the backside of the projectors some more to straighten them out. No big deal. I'll look into it tomorrow. I have yet to seal the capsules back up permanently until I get everything squared away.
