gonna get a 2 pod cluster for my GTP, i know im getting a boost gauge, but what other one is easy to install, and worth getting?
Easy enough just unscrew your dummy light and put the sender or tube and coupler in there Not any harder doing a boost gauge.
I've never had a problem, i always pick up some nylon 1/8" air brake line. The stuff they send in the kit's are garbage. This stuff is almost un-inkable and very hard to slice, but still really flexible. The easiest way is electrical sender one wire and you are done.
I know, the sender only has one wire going to it though. The gauge will have 4 wires coming off of it all together.
what about an aeroforce????? thats the best gauge i own....and its plug and play w/ a12volt switched wire ran to it....
