Thread: Debadge
Results 1 to 16 of 16
  1. #1 Debadge
    SE Level Member PeterCottonTail's Avatar
    Chicago
    I have a 98 grand prix gtp, i was looking to debadge it. Any problems i could run into? Are there going to be nipple holes? different color underneath? stuff like that, any help would be great thanks
  2. #2 Re: Debadge
    Wooster, Ohio
    Welcome and nope, there all on with 2 sided tape. The door moldings though are on with tape and clips, so if you decide to remove them you'll find a bunch of small holes behind there
  3. #3 Re: Debadge
    Chicago
    so like the GTP signs will leave holes? dang..
  4. #4 Re: Debadge
    Wooster, Ohio
    noo, the moldings down the doors, basically the door dingers, all the badges are on with tape, even the pontiac logo on the front bumper.
  5. #5 Re: Debadge
    swift current,sask.
    if done right you will never tell there was badges there.
    Debadge Attached Images
  6. #6 Re: Debadge
    Wooster, Ohio
    best way to do this is a get rubber wheel (called pinstripe remover in the parts world) which most places that carry body supplies, like a napa or paint shop will have these. Its basically a big eraser wheel that you can put on a die grinder or in a drill and with a little pressure will cut right through the left over tape and residue. First use a good scraper to break the tape and peel the badge, then rubber wheel on whats left, and finish up wiping down with laquer thinner or equalivalent. Will look perfect when done! The rubber wheel WILL NOT burn through your paint unless you are trying to, even then it would take a LONG time. I work in a very large collision shop and do probably 20 to 40 badges and pinstripes a week, so if you have any questions on anything with removal or reapplication i can help ya out!
  7. #7 Re: Debadge
    Chicago
    sweet, just trying to make sure before i jump into it. so no problems with paint color underneath?
  8. #8 Re: Debadge
    Wooster, Ohio
    as long as you don't take a razor blade or anything crazy to it, no. On silver i doubt you'll notice any fading at all, if it was black i would say you can tell but on how light your color is no.
  9. #9 Re: Debadge
    Chicago
    okay sweet thank you so much
  10. #10 Re: Debadge
    I live here. UR LOSN's Avatar
    Rockford, IL
    welcome
  11. #11 Re: Debadge
    West Side Michigan
    Welcome!!
    I used floss to take mine off and then some goo gone to get some of the goo off and then just a nice wash to rinse everything away.
  12. #12 Re: Debadge
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    let me know if u plan 2 get rid of the gtp emblems.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  13. #13 Re: Debadge
    Chicago
    haha naw those are staying with me
  14. #14 Re: Debadge
    so where are the finished results?
  15. #15 Re: Debadge
    Chicago
    ha waiting until its warm out to do that one
  16. #16 Re: Debadge
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    Quote Originally Posted by a98gtp4u View Post
    i have 2 gtp emblems, pm me a offer if you want, i can also send pics
  1. Debadge or no?
    By ls1camino in forum Visual/Body Modifications
    Last Post: 11-15-2009, 12:07 AM
  2. Whats the best way to debadge?
    By DnaProdigy in forum Visual/Body Modifications
    Last Post: 10-15-2008, 11:18 AM
  3. badge or debadge that is the question
    Last Post: 09-16-2008, 08:42 PM
