Thread: center console
Results 1 to 9 of 9
  1. #1 center console
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    My center console is getting really loose and squeekie when ever i open, close, or just touch it. its doing this cause the plastic is starting to get soft where the screws go into the bottom of the console not it the door its self. I was wondering if there is anything that someone has done to fix this. its really starting to annoy me.
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: center console
    SE Level Member X97prixX's Avatar
    Idaho
    Mine had a simliar problem, I looked into it I had to tighten the bolts on the bottom of the console underneath the cdholder inside the console. You might try putting large washers in their underneath to help hold it down a little better.
  3. #3 Re: center console
    Nov 2008
    how do you competely take that console apart i still haven't really figured out how
  4. #4 Re: center console
    SE Level Member Enzo354's Avatar
    USA
    Ive been thinking this over, mabye to just get a rectangle of metal, drill holes in it and then use it as a big washer.
  5. #5 Re: center console
    Nov 2008
    ya like on the back side of the plastic? that would make a lot of sense to me but the only problem is i dont know how to get the damn thing apart. help?
  6. #6 Re: center console
    USA
    Or on top of the plastic. It would be visible inside the thing but it would be the best.
  7. #7 Re: center console
    Charles City, IA
    Pull out the little cd holder then Fold out the cup holder pry up on the piece that holds that and it will pop off. Then you can get into the front of it as well as the top.
    SMGPFC Two Nipple General
  8. #8 Re: center console
    GT Level Member kjclawson's Avatar
    Fort Myers, Florida
    my center console is also pretty noisy but what is making the sweaking noise is coming from the top part that you lift up. idk if urs is coming from another place but i don't see how taking the whole console out would help??
  9. #9 Re: center console
    Nov 2008
    ive got a couple other things that i want to install and fix other wise i wouldnt bother
  1. center console
    By flash527 in forum Visual/Body Modifications
    Last Post: 11-18-2009, 02:43 PM
  2. Removing center console from 04+ GP
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 03-18-2009, 09:33 PM
  3. Removing center console
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-21-2008, 08:22 AM
  4. Removeing 06 center console? Help!!
    By ABINOK in forum General Tech Discussion
    Last Post: 05-11-2008, 11:25 PM
