Thread: Need help with a handle
Results 1 to 4 of 4
  1. #1 Need help with a handle
    Aug 2008
    Pennsylvania
    My car door handle on the inside i think is bent like the linkage stuff and the rods. Where do i get some new parts and what are they called so i can look them up?
    I Always Need Help
  2. #2 Re: Need help with a handle
    Wausau, WI
    Ed Morad parts should have some.........and I think that is what they are called. Inner door linkage rods..........just describe it and they can find it for you. Or your local junkyard. If you want new, I think only gm or gmpartsdirect would have them.
  3. #3 Re: Need help with a handle
    Aug 2008
    Pennsylvania
    Okay im bring this post from the grave pretty much. But i have found that the screws where loose a little when i took off the interior of the door. I tightened them and is definitely better but its not like super solid like the other doors are. im thinking it isnt the linkage rod now.
    I Always Need Help
  4. #4 Re: Need help with a handle
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    instead of fooling with it why dont you go to a junkyard and get the whole assembly....your pullig your hair out for a 30 dollar set of parts
  1. low idle....near stalls....can't handle load or deceleration...ahh
    Last Post: 05-16-2009, 01:18 PM
  2. engine can't handle load...
    Last Post: 05-02-2009, 02:51 PM
  3. How much N2O can a stock 3800 handle?
    By Quicklynx in forum General Tech Discussion
    Last Post: 10-27-2008, 08:38 AM
  4. Need help with the outside handle on the door =(
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:52 PM
