Thread: Offical DRL (Day Time Running Lights) Thread
Results 21 to 40 of 47
  1. #21 Re: Offical DRL (Day Time Running Lights) Thread
    SE Level Member ricardo23's Avatar
    Sonora, Mexico
    Quote Originally Posted by Stunt0Rider View Post
    Go slow and take stuff apart and resolder in LEDs
    hey man, can i PM you so you can help me out through the process??
    00 Grand Prix SE..
    apc air filter.. nothing but.. where do we start?
  2. #22 Re: Offical DRL (Day Time Running Lights) Thread
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    Why does everyone even give an f about drl's??? It's not a big deal, its a safety feaure. You can't turn your lighs on manually in our cars GET OVER IT
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  3. #23 Re: Offical DRL (Day Time Running Lights) Thread
    Apr 2009
    Wausau, Wisconsin
    Quote Originally Posted by ricardo23 View Post
    No, I never did it. I am assuming it is straight forward so if it was me I would get some parts from the junk yard and just go for it.
  4. #24 Re: Offical DRL (Day Time Running Lights) Thread
    May 2008
    I disabled my DRL by pulling the fuse located on the passenger side.
    2000 GT
  5. #25 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    I have looked for a fuse on my 2000 GTP and cant find one solely for the DRL. Also is there any way to disable the auto light feature? Getting annoying when im sitting in a parking lot and not wanting headlights on they are on either because of DRL or auto feature.
  6. #26 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    It's in the inside fuse panel located to the right of the glovebox once you open the glovebox. And like the first post said, if you pop the little panel off on the driver side dash (door has to be open to access, and unplug the connector, no more DRL.
    Note the bottom right fuse
    And this is where it's located
    Props to reviving a 4.5 year old thread and being on topic about it. Though reading the first post would have gotten you the answer you were looking for. Hope this helps.
  7. #27 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    Yea I know where the fuse panel and such is, Ill have to look again, but pretty sure last time I checked, I was pretty frustrated because I though that was my simple cure and it wasnt available or listed as a stand alone fuse on my car. and yea I know, they should all be the same, like i said I will check again to verify, Thanks for the reply, and advice on disabling the Auto lighting feature?
  8. #28 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    If by auto feature you mean the lights coming on automatically, yes, removing the DRL fuse, or unplugging the aforementioned plug will disable them. I personally pulled the fuse and unplugged said plug, then heatshrinked (electrical tape works just fine too) the connector. Head lights will only come on when I turn the knob to on.
  9. #29 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    No I have a separate auto lighting feature in addition to my DRLs. Basically runs of a photosensor in the dash close to windshield, so knows and turns on lights automatically when nightfall begins, separate sytem im assuming from the DRLs.
  10. #30 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    mine's got the same thing. Unplugging the connector from the heatsink will disable them. Did for my last 3 Grand Prix's
  11. #31 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    Cool, i will try that tomorrow, and the "heatsink" you are referring to is on the drivers side correct? Also noticed you have H1s, Do you have Halos? and if you do, could the drl function be wired to those or are they on a separate function within themselves. I know thats a lil off track, but just curious.
  12. #32 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    No halos. My old ebay projectors did and they looked neat, but I decided against them in my retrofits. You could wire them to the DRLs, or any switched 12v source.
    http://www.youtube.com/watch?v=-1Car4RCamE
    watch that starting at 1:10 in and it shows you exactly where it is. You do NEED to either tape it or heatshrink it because there will still be power to it which can short out against the metal support under the dash.
  13. #33 Re: Offical DRL (Day Time Running Lights) Thread
    Jan 2014
    Port Orchard, WA
    I tried doing a search but I came up empty. I have a 03 GTP that I have pulled the fuse and unpluged the heatsink. I get the clicking non stop. I need to be able to control the lights because I work on a military base. I have to turn my lights off so I can get my ID checked without blinding the guys at the gate. How can disable all that crap so I canturn my lights on and off? How do I unhook the light sensor? How do I turn off the DRLS?
  14. #34 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    ^ That super fast clicking is from a relay box under the driver side dash (right by where you unplugged the heatsink.) Mine started doing that superfast clicking stuff so I felt around under the dash until I felt where it was clicking, and unplugged it. No more DRLs, automatic lights, or clicking.
  15. #35 Re: Offical DRL (Day Time Running Lights) Thread
    Jul 2010
    Coquitlam,BC,Canada
    Some years are different, so by removing the DRL fuse, you get the dreaded clicking. I did. Yay!
    Solution: I put in a switch on the DRL module.
    To get rid of the Auto On, I tried the diode method, but that kept the lights on ALL the time.
    Solution: http://chrisb.users.superford.org/Gr...ght_Flash.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #36 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    Well guys I found the fuse (have no idea what in the hell i was looking at before but it obviously wasnt MY car, lol) anyway, worked!! so now with new posts here, am I to expect a clicking to start or does it do it right away? Thanks for the help anyway. At some point MAchinegun would like to chat with you about your retros somewhere besides here so no one gets mad for being off track.
  17. #37 Re: Offical DRL (Day Time Running Lights) Thread
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Fixedwing1 View Post
    .....am I to expect a clicking to start or does it do it right away?
    Right away.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #38 Re: Offical DRL (Day Time Running Lights) Thread
    Donating Users
    Jan 2014
    West Virginia
    Cool thanks.
  19. #39 Re: Offical DRL (Day Time Running Lights) Thread
    Jan 2014
    Port Orchard, WA
    Can you give me some type of description of what or where you unplugged it? Just something to give me a starting point please? Otherwise I will do the exact same thing. I can't stand not being able to control my lights. I can drive this 3,500lb car that is a projectile of death but I can't be trusted to turn the lights on? Get real......
  20. #40 Re: Offical DRL (Day Time Running Lights) Thread
    Florida
    A relay box (about 3" x 3" x1") under the driver side dash. When the ****er starts clicking like alll hell, feel around and you can most def. feel it clicking. Unplug the connector from that and no more clicking.
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. daylight running lights
    By stanggreg90 in forum General Tech Discussion
    Last Post: 07-08-2009, 12:42 PM
  3. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
  4. Time Running Out Klms Need To Know Things
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-19-2008, 09:28 AM
  5. Day time running lamps
    By Dohner in forum General Tech Discussion
    Last Post: 10-12-2008, 04:33 PM
