Thread: tinted tails
Results 1 to 19 of 19
  1. #1 tinted tails
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    Tinted my tails yesterday. They are a lot darker then i was thinking i would make them, I dont think they came out bad tho, but i want them to be shinier. So i might buff them if i can, or is there anything else i can do to get them to shine? What do you guys think?
  2. #2 Re: tinted tails
    London Ont, Canada
    wet sand, clear coat, buff
  3. #3 Re: tinted tails
    Pittsburgh
    even after i cleared the first time?
  4. #4 Re: tinted tails
    London Ont, Canada
    more clear = more gloss
  5. #5 Re: tinted tails
    Donating Users
    Plainfield, IL
    cleared wet sanded and buffed...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  6. #6 Re: tinted tails
    chicago
    did you use led bulb? ^^^
  7. #7 Re: tinted tails
    Aug 2008
    KCMO
    contact flip and have them done pro. and call it quites and not have to worry about it
  8. #8 Re: tinted tails
    Donating Users
    Plainfield, IL
    Quote Originally Posted by silverbullet View Post
    no i have newer set that are a shade lighter than those...and dont need leds it looks like the pic above but when the sun hits it you can still see a hint of red
  9. #9 Re: tinted tails
    Donating Users
    Plainfield, IL
    debadge your trunk btw...
  10. #10 Re: tinted tails
    Pittsburgh
    Quote Originally Posted by carl06GT View Post
    i would but im tight for money atm and i like doing this stuff
    Quote Originally Posted by gotboost3 View Post
    just pull it off? i guess the paint might be poopy under it?
  11. #11 Re: tinted tails
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    Quote Originally Posted by EmEaston24 View Post
    debadging
    Call me Brad
    '06 GT: Just a few mods here and there.
  12. #12 Re: tinted tails
    Pittsburgh
    had to take all the clear off the one yesterday. bit freaking pain. but they came out a little better
  13. #13 Re: tinted tails
    Pittsburgh
    i think im gunna put more clear on the left one. looks a little dull
  14. #14 Re: tinted tails
    your first pictures look like the tails on my car. i just wanted them dark, i dont care if they are shiny or not.
  15. #15 Re: tinted tails
    Pittsburgh
    ya i didnt really care at first, but i saw some pics of shiny ones and i liked them better
  16. #16 Re: tinted tails
    canada
    what did you use and do you have night shots
  17. #17 Re: tinted tails
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    its actually really easy. it just takes time and patience. once you have the nightshade and clear on, and everything is dry, all you need is 1500-2000 grit sandpaper, a spray bottle full of soapy water, some buffing pads that could go in a drill or buffer, and some buffing compound. now i found my buffing pads at a local tool store that came in a kit and fit right into my drill that work great. as for the compound, i used meguiars fine cut polish, and the their show car glaze. all you do is use the spray bottle and sandpaper together to LIGHTLY wet sand the top layer of clear. make sure you dry it off every once in a while to check your progress. once you have a pretty even "haze" over the whole light, use the fine cut polish. i did a couple of coats of this, making sure to wash and dry between coats. then i moved on to the show glaze. this is where the shine starts to come back through. after you apply a couple coats of this stuff, it should be pretty damn shiny. i know mine were and i love em. only problem i have with mine is they are a little too dark for day driving. you can barely see the lights if its sunny out. good luck bro
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  18. #18 Re: tinted tails
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    what kind of clear are you guys using for this?
  19. #19 Re: tinted tails
    Donating Users Warbeaver's Avatar
    St. Louis
    please follow the writeups in the "VHT" thread at the top of the "visual/body modifcations" section. Mine is in there somewhere on the last 2 pages and it has pics of what to do and what to use
    http://www.grandprixforums.net/f11/v...e-5662-10.html
  1. Tinted Tails
    By mwalk00gtp in forum Visual/Body Modifications
    Last Post: 05-08-2009, 07:48 AM
