Thread: Water in headlights?
Results 1 to 10 of 10
  1. #1 Water in headlights?
    Apr 2008
    Hi,
    I have noticed that water gets into my headlamp fixtures. I am wondering if there is a fix for this or if I should just get new headlamps? I do want to get a HID kit also so I am thinking my best bet would be new headlamps+hid kit.
    Can anyone link me to a good site to buy headlamps and hid kits that will be very easy to install. I can follow instructions but don't want to do drilling and stuff like that I am looking for plug & play. Thanks!
  2. #2 Re: Water in headlights?
    GTP Level Member dstout's Avatar
    ky
    Yep they do leak, all the stock lights leak and then they don't look good and the light output is pretty bad.
    Another member posted this link
    1997 1998 1999 2000-2003 GRAND PRIX HALO HEADLIGHTS+HID:eBay Motors (item 140317856919 end time May-05-09 11:07:51 PDT)
    It says the bidding ended but just scroll down a bit and you will find them.
    You really can't beat that deal as they come with HIDs and if that's what you are wanting then go for it.
  3. #3 Re: Water in headlights?
    Apr 2008
    Quote Originally Posted by dstout View Post
    Those are what I am looking for. It says "Professional installation is highly recommended." Is there some kind of cutting or drilling that needs to be done or why does it recomend a pro to do it? Hopefully it is just plug and play using same bolts and everything. Has anyone done this mod and can post pics of how it looks on their GP?
  4. #4 Re: Water in headlights?
    ky
    I don't know why they say that I think it's just a disclaimer I don't think you will have any problems installing these.
    There were fittment issues with the very first ones that were produced.
    Those look nicer and built better than mine do.
    You should be able to just swap out the old lights for the new. It isn't difficult to do. It looks like the heavy duty wiring harness is included for the HID's and that's a good thing.
    There should not be any cutting or drilling involved.
  5. #5 Re: Water in headlights?
    Apr 2008
    Does it come with instructions on installing? The only thing I would be curious about is where to plug in the new wires and everything otherwise doesn't look hard at all. I am going to get some money together and see what I can do. Thanks for the link and info!
  6. #6 Re: Water in headlights?
    ky
    No instructions came with mine, but there are pretty straight forward and if you do have questions or get stuck just post up here and you will have some answers. Don't sweat it it will be easy.
  7. #7 Re: Water in headlights?
    Apr 2008
    Alright cool thanks for the info! One question though. I have my amp/subs hooked up to my battery and if I hook up these lights am I going to have problems with it draining my battery and if i decide to get HID fogs will that be even worse? I want to upgrade the fogs too not sure if they are worth HID's if i get these headlights or should I just get better bulbs for them?
  8. #8 Re: Water in headlights?
    ky
    Not sure about that someone else might know. How old is the battery?
  9. #9 Re: Water in headlights?
    Apr 2008
    Just got it may 1st 2009 along with a new starter, headgasket, sparkplugs, wires...
  10. #10 Re: Water in headlights?
    ky
    I don't think you would have a problem with draining the battery unless you forget and leave the headlights on all day long.
  1. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  2. water in fuel...maybe?
    By GTPGP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 09:46 AM
  3. Water on floor
    By karkrazy1971 in forum General Tech Discussion
    Last Post: 12-22-2008, 08:24 PM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  5. Water in headlight...
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-14-2008, 03:37 PM
