Thread: SD front air dam what do you know about them.
Results 21 to 40 of 47
  1. #21 Re: SD front air dam what do you know about them.
    SE Level Member ayman's Avatar
    Michigan
    Quote Originally Posted by GP2003GT View Post
    i eventually want that front air dam as well, but would there be a problem with the lower grills inserts? or wont it matter
    a little... you'd just have to do a little bit of bending to make em fit depending on what type of grills you bought. It's no biggie though....
  2. #22 Re: SD front air dam what do you know about them.
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    alright, yeah i got the grills from pfyc.com and the year of my car has those air dams blocking the way so i already have to fight with those...lol
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  3. #23 Re: SD front air dam what do you know about them.
    SE Level Member SDGrandPrixGT23's Avatar
    San Diego, California
    Ive heard that on some colors it doesnt look good because of the way the front end is molded. Like the big color was white cuz it shows gaps and different ways you look at it almost looks out of place. I have a white '01 and Im hessitant to buy because of that
  4. #24 Re: SD front air dam what do you know about them.
    GT Level Member SD GTP's Avatar
    Kirkwood, Delaware
    The grills you can do one of 2 ways:
    1) you can rebend them thinner to make them fit with the air dam however, I am leaning away from this route as you run a risk of scrapping up your air dam with it.
    2) if you put the car up on ramps, you can actually side the grills up from underneath the front end. You will need to get a few self-tapping screws and washers and drill holes in the plastic guard and that way you have your grills, they will sit flush with the rear of the air dam, and no paint scratches. I'm going to be doing this this weekend so I'll be sure to take pictures and post a write up.
    As far as paint, take it to your local body shop and make sure they blend the paint. The other option is contact Steve Blount (I'm not sure if he's on GPF but I knwo he's on ClubGP). He actually molded his air dam and front plate filler in then had it painted. That way you get rid of any gaps and it makes it looks like a stock piece,
    MACGP President
    3.25"/P&P Gen III/ZZP Stg II TB/Thasher CAI/ZZP VS Cam/TOG Xtremes/AL 104s/180*/Full 3" Exhaust/SD Package/GMPP Sways & Arms/DuBob'd
  5. #25 Re: SD front air dam what do you know about them.
    Fayetteville, NY
    ok yeah that would be cool...
  6. #26 Re: SD front air dam what do you know about them.
    GTP Level Member David99GTP's Avatar
    Florida
    Steve will tell you that with the air dam and if your car is lowered you will hit everything. He has had issues with that. Molding looks sweet but is a lot of work and expensive to have done. I was going to have mine done until I spoke to Steve. Mine is being painted and I am installing it as is. I do agree the darker the paint the better it looks. Blends in better. I have heard good and bad as far as fit. Matt and I seem to have been lucky on a good fit. I have heard from some other members theirs didnt fit very well.
    Worst part of the air dam is shipping. Almost as much as the piece itself.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  7. #27 Re: SD front air dam what do you know about them.
    Port Hope Ont,Canada
    I did not have no problems installing mine
    and if for any reason i would have to remove my
    SD chin i do not have to remove the bottom grills
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  8. #28 Re: SD front air dam what do you know about them.
    Fayetteville, NY
    yeah thats how i want mine to look with the air dam and the grills...
  9. #29 Re: SD front air dam what do you know about them.
    Jan 2009
    Brooklyn NY
    my god that burgundy GP is so sick.
  10. #30 Re: SD front air dam what do you know about them.
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^I concur!!
  11. #31 Re: SD front air dam what do you know about them.
    GT Level Member TJs97's Avatar
    NJ
    I don't have any experience w/the air dam itself. BUT I do know that if shipping wasn't practically the same cost as the air dam, I'd have 1
  12. #32 Re: SD front air dam what do you know about them.
    Fayetteville, NY
    this is mine...
  13. #33 Re: SD front air dam what do you know about them.
    the hardest part is deciding on painting it all the same. or painting it like stock?
  14. #34 Re: SD front air dam what do you know about them.
    May 2008
    McHenry IL
    that air dam is sick! iddoit all the car color then repaint the rear 2
  15. #35 Re: SD front air dam what do you know about them.
    Fayetteville, NY
    see i did it all the same color cause the rear on my car is the same color as my car, its not the grey that is on most..
  16. #36 Re: SD front air dam what do you know about them.
    Donating Users nvsridez's Avatar
    sw WI
    Quote Originally Posted by SDGrandPrixGT23 View Post
    i think it looks ok on white.... i'll admit it was hard to get it on there perfect. i almost thought about actually molding it into the front bumper. hope this pic helps u make up ur mind.
  17. #37 Re: SD front air dam what do you know about them.
    GT Level Member Dohner's Avatar
    Montpelier
    Holy crap man those are that bomb. Dose anyone know if they have come down in price at all and where did everyone get theres at. Thanks
  18. #38 Re: SD front air dam what do you know about them.
    Fayetteville, NY
    dont think they came down in price, i got mine from pfyc.com in the exterior section
  19. #39 Re: SD front air dam what do you know about them.
    sw WI
    Same here
  20. #40 Re: SD front air dam what do you know about them.
    Florida
    If anything they will get more expensive until they arent made or available. Remember roof rails? PFYC had em and now you cant find them. If anyone is on the fence regarding the air dam buy it before it's too late.
    GP no longer made = less and less parts
    1999 GTP
  1. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
air, dam
