Thread: Rocker panel surface rust repair?
Results 1 to 12 of 12
  1. #1 Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    My car has pretty solid rockers. Recently the underside of the rockers and the pinch welds have started to have paint peeling off them with surface rust forming. The drivers side rocker has a small spot that has bubbling paint that has came up along the side and you can actually see it below the door. I poked around the its all still solid metal.
    What do you think about this? I ordered por-15, por-15 metal prep, and Por-15 top coat gloss black.
    Should i sand down the rockers to bare metal, spray the metal ready, apply the por-15, and then apply the por-15 top coat? My car is already black so I don't really care about it matching entirely but I think it'll be close. I just want to slow the rust down. I also thought about just por-15ing the underside of the rockers and then fixing the bubbled paint with my touch up pen for now. When I say underside I mean the part of the rocker that curves down and faces the ground and meets the pinch weld so it wouldn't be visible unless you looked underneath. I think my paint code is wa8555. Its gm black.
    Also, what's the best sanding tool to use? A sanding block for rusty metal? An angle grinder? Orbital sander? What kind of grit sandpaper should I use?
  2. #2 Re: Rocker panel surface rust repair?
    Nov 2012
    Madison
    What year car?
    I wish it was in everyones profile..hint, hint.
    I am no body man, I spray the underside spots in spring and fall with Rustoleum industrial black and say f**k it.
    Some of the rough stuff you will want some wire brush action. The metal prep is some good stuff. Did you order the cleaner to?
    Anyway if it's a smooth spot, yeah you will want to sand it bare. The problem is you are not spraying, which would cover 600-800 grit I believe.
    You also would want some primer action on bare stuff.
    Get some wire brushes both nylon and brass or stainless.
    Perhaps PM Idrivejunk.
    He is very helpful and a full blown bodywork artist
  3. #3 Re: Rocker panel surface rust repair?
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    My car was garage kept and hardly driven before I got it so it was in great condition. I was stupid and used the pinch welds several times to lift the car (until I got smart enough to just start lifting at the center of the car under the front and rear subframes). As a result the paint was chipped off and surface rust started to form on the pinch welds. You can check out what I did on this thread http://www.grandprixforums.net/threa...78#post1465278. Por 15 should work the same if not better. I hand sanded, but I had just a hint of rust. If you have a decent amount of rust I would just hit it with a power sander down to the fresh metal and prep and paint. I also used a paint that was very close to the color of my vehicle ("Bronzemetallist") and you can't even tell. So black should look fine.
    The bubbling paint has me concerned, usually it only bubbles when it comes from the other side of the panel. Maybe you'll get lucky and sand it out and it won't be a hole, but there's always a risk. If your rockers are still good I highly recommend spraying some rust inhibitor or old oil/transmission fluid inside those rockers. And I mean flood them if possible. Here's a thread describing what I did to get to the insides of the rockers http://www.grandprixforums.net/threa...87#post1465387 I ended up spraying even more myself later.
    Finally I tossed on some mudflaps to keep rocks from dinging up my rockers. I installed fronts and backs, but the backs are optional for this purpose. Here's some pics on this thread http://www.grandprixforums.net/threa...97#post1474697
  4. #4 Re: Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    Actually the car I'm doing this on is a cobalt LS lol. The cobalt is black. The paint code for it is wa8555. I'm just on here cuz I also have a GP and this site is where I found out about por-15 along time ago. When I put in the paint code 'wa8555' on duplicolor's website, only one spray paint pops up for the car and it is universal and is called "gloss black". The rockers are solid on the outside and are solid when I tap them. But I do see a small section of bubbling below the door. It's mostly paint flaking off on the underside of the rockers. I just want a temporary fix for now.
    I'm thinking of sanding down the entire rockers to bare metal and just using the 'por-15' and 'por-15 top coat' as the finish. The por-15 top coat is called "gloss black". So it would definitely be something you would see looking down at the car. I'm just worried that the two different blacks would be off or look tacky. Just look up a black cobalt ls for reference. Does anyone know if I can use body filler with por-15? I'm scared about what gingerdude said about sanding and there being some holes.
    What's the best way to sand to bare metal? 60 grit? 80 grit? I don't have an electric sander or angle grinder.
  5. #5 Re: Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    I have tons of used motor oil lol. Would that work? I have tiny holes on the bottom of the rockers,, how the hell do I spray the insides? I have no compressor...
  6. #6 Re: Rocker panel surface rust repair?
    Dec 2016
    IL
    You'll have to rig up something. I just bought cans of the Corrosion Free and used that to spray inside. I know Lowe's sells Fluid Film for $10 a can and it's supposedly a decent rust inhibitor. At least that will spray out of the can for you if you can't think of anything else. One can should handle both sides.
  7. #7 Re: Rocker panel surface rust repair?
    Jan 2014
    AR
    Duplicolor universal black matches 8555 decent but looks browner in strong light, and the gloss level is obviously less. Clearcoating and buffing both help that. 80 grit on a dual action sander is the universally preferred prep method for bare metal. Paint Over Rust type products are not designed to work on bare steel. Epoxy primer is the only choice for pros on that. Get rid of the rust by using multiple applications of an acid based rust treatment product and wire brush. Rattle can etch primer allowed to flash dry and followed by black paint is the hobbyist-in-driveway choice I would prefer. Products not using a catalyst can't be expected to live long and are more easily damaged than the original finish so leave as much of that as you can. If you rustproof with oil, I hope you don't live on a dirt road or mind carrying around solvent and rags for when it migrates to the exterior finish.
  8. #8 Re: Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    Do you know if the por-15 metal prep spray will work on bare metal to help por-15 to adhere to it? I read somewhere that was one of the purposes of the spray. And I think I've seen YouTube videos where they spray it on clean metal without rust and then they paint the por-15 and the por-15 sticks on with no problem.
  9. #9 Re: Rocker panel surface rust repair?
    HUDSON
    Best thing for treating and stooping surface rust is "OSPHO" (phosphoric acid), then paint as desired.
  10. #10 Re: Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    Already ordered por a few days ago. Has anyone ever used this stuff as a finish on rockers? I see cars all the time here with black coated rockers but can't find a pic online lol. I always see por on pickup truck rockers
  11. #11 Re: Rocker panel surface rust repair?
    Dec 2016
    IL
    Personally I'd rather have slightly off colored rockers then super rusty ones. I'm sure it won't be noticeable.
    Yeah if you coat with the oil it will creep up your panels slightly. I don't mind because I know it's spreading well and I just blast it off with the hose.
  12. #12 Re: Rocker panel surface rust repair?
    Sep 2015
    Lansing, Michigan
    I see people use all sorts of products on their rockers but never see por-15 unless it's when they're welding on new rockers and they use it on the insides. I never see it used as a finish on the outside. But I doubt it'll hurt anything as long as I use the por-15 top coat
    i figure it may hold a few years and by then I'll know how to weld and I can just replace them once they get super rusty.
  1. 2001 GP SE Rocker Panel Repair - Update
    By AJ1G in forum Visual/Body Modifications
    Last Post: 01-03-2016, 09:53 AM
  2. 2001 GP SE Rocker Panel Rust Repair
    Last Post: 07-18-2015, 08:00 AM
  3. rocker panel rust
    By ad356 in forum General Tech Discussion
    Last Post: 12-06-2013, 01:19 AM
  4. Rocker panel rust repair
    By natethegreat in forum Visual/Body Modifications
    Last Post: 09-25-2012, 10:48 PM
  5. Rocker panel rust, suggestions? (Pics inside)
    By aeidian in forum Visual/Body Modifications
    Last Post: 07-12-2012, 10:53 PM
