Thread: Yup I'm going turbo on my camaro 3800 - planning phase
Results 1 to 9 of 9
  1. #1 Yup I'm going turbo on my camaro 3800 - planning phase
    GT Level Member bachert24's Avatar
    Jan 2015
    Obviously without actually measuring a bunch of crap you have to make some assumptions with numbers. I tried to be realistic on these so if you see any errors let me know so I can make more adjustments. I am not going to delve into my absurd list of mods right now. While some if it relevant, I want to just concentrate on hard numbers for the time being. Now please realize that I am not looking for an exact HP or 1/4 time. These are just reference points.
    Target Crank HP=575
    Engine Displacement=232
    Running on pump gas with hopefully 11.5:1 Air/Fuel ratio
    BSFC=.46 (estimated)
    VE=75% (pretty sure I went low on this)
    Mid Range Estimated RPM=6000 (i used a number where I would be close to top of the TQ band)
    Peak Power Estimated RPM=6500 (I will have to look into cams cause I don't think my current one will push the RPM up this high and still make power)
    I am going with an Air/Air intercooler with an estimated 1 psi drop and with an assumed effectiveness of about 70%.
    Typical barometric pressure in MI of 14-15
    Ambient temp=80 (went with a realistic summer temp on this)
    These numbers will net the following
    MID RPM:
    Crank HP-531
    Boost Gauge PSI=20 (yes i know i will need a perfect tune)
    Pressure ratio=2.46
    Intake manifold temp=146F
    Corrected airflow=47.96 lb/hr
    Crank TQ=465
    MAX RPM:
    Crank HP-576
    Pressure ratio=2.46
    Corrected airflow=51.95 lb/hr
    Crank TQ=465
    Based on that info and looking at the Turbo map i think the best Turbo for this would be GTX3582Rhttps://turbobygarrett.com/turbobyga...arger#GTX3582R
    It looks like the efficiency is around 78% and is very close to the island.*
    With making super huge assumptions this would put a 3400 lb car at close to 11.1 @ 122mph in the quarter mile.*
    I haven't looked into any housings yet so if you have any advice i am all ears. Again for the sake of people trolling the crap out of this thread, realize these numbers are just hard numbers, nothing is set in stone and a lot of this is realistic, but also assumed.
    Sent from my LG-ls990 using Tapatalk
  2. #2 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    GTP Level Member
    Jan 2015
    Lincoln, NE
    My advice is leave the garrett on the shelf and call precision...
    Edit: you won't make that kind of power on pump gas most likely will need e85.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    Jan 2015
    Quote Originally Posted by NebTurboST5 View Post
    Ill check out precision, thanks for the advice
  4. #4 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    You might want to reach out to FurchesPerformance (vendor on the site) as he does a lot of F body stuff. Cool stuff.
  5. #5 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    As an fbody guy, why not LS swap it. Especially if you're fine with running low 11's or high 10s, 4.8 or 5.3 with 243 heads, a cam, ls6 intake, and headers with a 150 shot will get you there. Better transmission options as well. And that build would cost a fractio as opposed to a 5.7l or 6.0l, even a big turbo 3800 build. Put the rest of the left over money into wheels, tires, and suspension if it's going to be raced.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  6. #6 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    Kemmerer, Wyoming
    I have no practical experience with turbo's, or even camaros, so all I really am is a keyboard warrior, but it was my assumption that aggressively ported heads with an aggressive cam and a big turbo would make 500+ hp on a 3800. I've thought about doing the same build and am still considering something along these lines. if I could ever make up my mind on what I want to do.
    and if you can deal with not having a compressor map, you could consider www.on3performance.com, they have really cheap turbos, and from what I've heard they are solid.
  7. #7 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    Jan 2015
    Ill look him up, thank you!
    Quote Originally Posted by SgtMarshal View Post
    Thanks, I'll check that site out. Its possibly I'll be over 500hp at the wheels, but I wanted to be realistic and these numbers do not take any other mods into consideration. Gearing, headwork, headers, exhaust... All of this will help as well.
  8. #8 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    Jan 2009
    Tallahassee, FL
    Also check out fullthrottlev6 if you're not on there. The forums are pretty dead nowadays since everyone has move to different platforms but everything is still there. Lots of great 3800 Fbody info there.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #9 Re: Yup I'm going turbo on my camaro 3800 - planning phase
    Kemmerer, Wyoming
    another thing to consider if the car is going to be doing the 1/4 mile is an air to water intercooler with a huge ice box reservoir in the trunk. frozenboost sell them on their site, and there are a few other places online that do them as well.
  1. My L67 Turbo Camaro
    By SharkBite in forum Members Rides
    Last Post: 03-29-2013, 08:19 PM
  2. Interesting read. 3800 camaro build. lots of info and data
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2012, 11:38 PM
  3. *96 Camaro 3800 Rebuild*
    By Austin2000SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2011, 10:19 AM
  4. 96 3800 camaro vs 00 grand prix
    By Austin2000SE in forum Track Sessions and Kills
    Last Post: 06-20-2011, 09:54 PM
  5. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
