It's running pretty well except it's stalling here and there (O2 sensor is sending erronous info since I put leaded fuel in the tank).
Also a strange issue... can't get car in 1st gear. It starts in 3rd gear or maybe Overdrive when in D, and when I put in the shifter in 1st, I'm in 2nd gear.
The good news is I have enough power to smoke my tires badly in 2nd gear. But with the slicks...won't be good.
We did not remove the wiring harness but we moved it (the one over the top of the trans). We didn't cut any wires.
Also we did a compression test and we had a trans line not connected to the rad and we lost about a cup of trans fluid which we put back in.
The trans was perfect before going turbo. Any ideas guys ?
ON the good side.
It's running and is already been tuned.
I have no video since the final tuning, it's quite a bit more powerful.
Still showed promise already during initial tuning.
16 psi of boost.
Bone stock 150K engine and trans.
Stock stall converter.
Building 7 psi easily in short time off the line and burnout in 2ND Gear with 80mph tire speed according to datalog (HP tuners)
https://www.youtube.com/channel/UCYI...GWzUGTZhh1ASvQ
