Thread: Intake manifold
Results 1 to 20 of 24
  1. #1 Intake manifold
    Nov 2012
    I currently have a L36 block with L26 heads and intake manifols. Is it possible to turn the upper intake manifold to the passenger side so that I can have more room for the turbo what all would I need to do to make it work if possible or what would you recommend?
  2. #2 Re: Intake manifold
    i think a camaro 3800 intake would work for that.
  3. #3 Re: Intake manifold
    Florida
    F-body intake from their N/A 3800s
    OORRRR be a BAMF and make your own upper mani
  4. #4 Re: Intake manifold
    You could try a Holden intake IIRC there was a guy selling a few in the classified section.
    04 Comp G.
  5. #5 Re: Intake manifold
    Florida
    To do the F-body you'd need the F-body intake manifold (not sure if you'd need the lower intake mani off the F-body or not, let's just say you do)
    You'd need to relocate the battery, Throttlebody adapter (to what every TB you're using) and extend all the sensors/PCV
  6. #6 Re: Intake manifold
    Florida
  7. #7 Re: Intake manifold
    Nov 2012
    Sounds good That custom one looks BA. I just want the extra room going to figure something out.
  8. #8 Re: Intake manifold
    hangover park IL
    youll need the upper and lower intakes as well as the TB (cable or DBW) and youll have to switch to the early horizontal bolt alternator and tensioner. the upper hose is fun...i didnt like the angle the pipe hit the TB/maf so i made an adaptor turndown to use the L67 TB with a straight shot at the tb/maf for nearly 16".
    battery relocated to drivers fenderwell with turbo discharge pipe routed going straight down and around the AC accumulator and then around the subframe/rad core support to the IC inlet to avoid any tubing through the fender.
    someday i will have a custom mailbox upper for the Fbody lower for this flamming heap
    ~James~ Psychotic Gearhead
  9. #9 Re: Intake manifold
    Nov 2012
    Turbocharged400sbc would you want to help me with this install if I decide to do.
  10. #10 Re: Intake manifold
    hangover park IL
    i dont have the time with my current project load but its not that bad...plenty have gone the F body route without nearly as much expense/custom fab work.
    to put it into perspective...just the parts for that upper radiator hose is nearly 200$
  11. #11 Re: Intake manifold
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    what masterpower turbo is that?
  12. #12 Re: Intake manifold
    May 2012
    Where winter never ends
    Stattama Sheet Metal!
    2000 Regal - Winter Beater
  13. #13 Re: Intake manifold
    Nov 2012
    Anyone have complete walk through on this
  14. #14 Re: Intake manifold
    May 2012
    walk through on what
  15. #15 Re: Intake manifold
    Nov 2012
    The actually replacement on how to switch out everything for the intake manifold
  16. #16 Re: Intake manifold
    May 2012
    With mine, i took off my blower laid some silicon down for a gasket and bolted it down. not hard
  17. #17 Re: Intake manifold
    Nov 2015
    Monroeville, Pa
    Does this intake swap work for the L67??
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  18. #18 Re: Intake manifold
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by nate halter View Post
    Don't go full retard.
    GPONA #1 Cyber Bully
  19. #19 Re: Intake manifold
    Omaha, NE
    Yes, if you're getting rid of the supercharger. In that case, you would also need the lower intake manifold and heads from an N/A car to match.
  20. #20 Re: Intake manifold
    I'd suggest reading and research.
    Because asking these questions make me chuckle like the toddler I am.
  1. Intake Manifold
    By Speedy1973 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2014, 09:00 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. intake manifold
    By eightballe in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2011, 01:30 PM
  5. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
