Thread: oil in valve cover breather
Results 1 to 20 of 31
  1. #1 oil in valve cover breather
    nj
    i have a valve cover breather and a catch can, can anyone suggest a way to minimize the oil coming out of the valve cover breather? or is that just normal?
  2. #2 Re: oil in valve cover breather
    I live here. DirtDog's Avatar
    Jun 2012
    Why do u have a valve cover breather
  3. #3 Re: oil in valve cover breather
    Jun 2012
    That's just unmeasured air entering motor
  4. #4 Re: oil in valve cover breather
    nj
    bc im turbo'd. i was told i needed one by others running a ct kit on my car
  5. #5 Re: oil in valve cover breather
    Jun 2012
    Awww good one turbo makes since. From what I can figure oil on it could just be the way it splashes up there....rockers and all that **** there
  6. #6 Re: oil in valve cover breather
    Ohio
    Hook up a catch can.
  7. #7 Re: oil in valve cover breather
    He has both.
    So remove the breather and just use your catch can.
  8. #8 Re: oil in valve cover breather
    nj
    oh ok i can remove the breather? i didnt think i could but ok i will try that. my valve cover breather is soaked.
  9. #9 Re: oil in valve cover breather
    Florida
    some people drill a hole in the oil fill neck just below the cap... oil_fill_1.jpg this kinda thing... i know diff engine. but then drill a hole and put a barb fitting on it and run that hose to the intake/ air filter area that does not see boost.
    well i guess if your maf is on the boost side this doesnt matter either.... but you can now use this setup to connect to the catch can and vent the air there. If your seeing a bunch of oil it is possible you have lots of blow by and that is why you are seeing the oil... or part of your original pcv system is still trying to work and you are pushing boost into the crank case.
  10. #10 Re: oil in valve cover breather
    nj
    ok . i currently have the catch can connected to the nipple where the pcv is at on the uim right by the intake (UIM side). so drill a hole under the cap, barb it and then connect that to the intake ( maf is after the turbo) then use the catch can to it? am i getting a t barb fitting? im sorry for the noob questions just have never done it oor seen it this way
  11. #11 Re: oil in valve cover breather
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    i run 2 front valve covers, 2 breathers, on my twin charged setup. both breathers have a piece of foam rubber in them to keep any oil from coming out. Works like a charm. havent seen a drip.
  12. #12 Re: oil in valve cover breather
    nj
    hmm care to show a picture please
  13. #13 Re: oil in valve cover breather
    Feb 2009
    flintnasty MI
    I have a stock breather setup using a LS1 fill adapter, works fine. Most the oil I see come out of them is rocker related, so moving the breather away from the rockers helps.
    i also run 2 breathers.
  14. #14 Re: oil in valve cover breather
    nj
    ahh, never thought it could be rocker related. i removed the valve cover breather and just using the catch can now. had to reroute it but we shall see how it goes.
  15. #15 Re: oil in valve cover breather
    nj
    So I put the stock valve cover on and after driving for 30 min I had white smoke coming out the exhaust..a lot of it. With the valve breather it didn't happen. So I put the breather back on till I get some suggestions on why it's doing it. Any ideas?
  16. #16 Re: oil in valve cover breather
    May 2008
    Schuyler, NE
    I believe at one time, you were running a vac pump on your Fiero. Did you decide to get away from that?
  17. #17 Re: oil in valve cover breather
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Quote Originally Posted by silver3 View Post
    Blow-by...crankcase pressure is building up and forcing past the rings into the combustion chambers.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  18. #18 Re: oil in valve cover breather
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by danomite02 View Post
    Yup! I only run one valve cover breather and have a cheap absorbant sponge type head/sweat band with the elastic cut off folded in half and tucked inside the VC breather...works great for my setup.
  19. #19 Re: oil in valve cover breather
    nj
    Quote Originally Posted by ls1camino View Post
    hmm so the only way to avoid it is to have the vc breather im guessing
  20. #20 Re: oil in valve cover breather
    dont know if the turbo caused the blow by, but when that happens the oil ring on the piston is dead in a N/A engine.
    i had this in a old car, the dip stick was getting blown out of the tube, and spitting oil up the tube as well. the pcv tube was also full of oil.
  1. How to get PCV to work instead of valve cover breather!
    By sseilmnop in forum How To Write-Ups/Tech Tips
    Last Post: 07-21-2014, 11:47 AM
  2. Valve cover breather
    By DoubleBlown in forum Turbo
    Last Post: 08-27-2013, 08:08 PM
  3. Valve cover breather ?
    By mikey666 in forum General Tech Discussion
    Last Post: 05-02-2013, 07:17 AM
  4. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  5. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
