Thread: HELP! white smoke out of exhaust after accelteration ??
Results 1 to 20 of 27
  1. #1 HELP! white smoke out of exhaust after accelteration ??
    SE Level Member 05gpturbo's Avatar
    Apr 2013
    wyoming MI
    i got a turbo grand prix that at times white smoke would come out of exhaust after hard acceleration, could this be a bad seal on turbo or valves?? i'm just hoping nothing major like pistons or something. still runs awesome! but at times it will smoke up after hard take off... anyone had this issue before??
    TURBO GT.. ETC ETC
  2. #2 Re: HELP! white smoke out of exhaust after accelteration ??
    Dec 2012
    Where 4T65E's were born
    White smoke is either normal when the weather is cool, and the engine hasn't warmed up, or cold out and it will always have a little moisture visible. If it's warm and still making white smoke, it's usually water (coolant) that is being burned/mixed in the combustion process. Has your coolant level been going down lately? That's the first thing to check, as well as with our cars, checking the dipstick to make sure there is no foam (Oil/water mixed).
    Edit: Nevermind, you later mentioned "smelly smoke" with a turbo.
    Sold.
  3. #3 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    yeah i will check that out later this afternoon. it only does it at times cause i've slammed on the pedal and had nothing come out
    TURBO GT.. ETC ETC
  4. #4 Re: HELP! white smoke out of exhaust after accelteration ??
    02...he's turbo. Very good chance there is an oil seal going bad. There is a way to check, I'm not that familiar though whether you check intake or exhasut side.
  5. #5 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    yeah i was thinking a seal but not sure where to locate lol
    TURBO GT.. ETC ETC
  6. #6 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    hopefully someone will let me where to find this issue, i hate having that smelly smoke come out!!! hope to get it fixed before the wbody intense meet this saturday!!!!
    TURBO GT.. ETC ETC
  7. #7 Re: HELP! white smoke out of exhaust after accelteration ??
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    When it happened to me it wound up being a bad turbo seal
    Here is a video of it at idle. Did it also after I hit the gas and let go
    http://www.nymcgp.com/members/silver...GTPproblem.wmv
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #8 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    well mines dosent smoke while its parked it just happens when i accelerate hard n let off the gas then smoke comes out
    TURBO GT.. ETC ETC
  9. #9 Re: HELP! white smoke out of exhaust after accelteration ??
    Feb 2008
    NY
    Quote Originally Posted by 05gpturbo View Post
    That's how mine started. Then it started to do it at idle.
  10. #10 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    oh alright thanks!! is it hard to do the seal?? i dont even know where to get one at
    TURBO GT.. ETC ETC
  11. #11 Re: HELP! white smoke out of exhaust after accelteration ??
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I hate you for being able to go to that.. Hope you get it figured out.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  12. #12 Re: HELP! white smoke out of exhaust after accelteration ??
    Feb 2008
    NY
    I did something better then change the seal. I upgraded to a bigger turbo.
    Don't know how hard it is.
  13. #13 Re: HELP! white smoke out of exhaust after accelteration ??
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    First question is going to be if you're running an oil feed restristor on the turbo? If you aren't running one anything above 60psi, which is easy for the 3800 to do can push past the turbo seal....especially one with some age on it. If you are running a restrictor and the problem is still happening then you have a seal going bad, particurlarly a the "step gap piston ring".
    MHI TD04 Turbo Parts- Step Gap Piston Ring for TD04 Turbo
    As far as difficulty to change it's not bad at all. I attempted the rebuild on my own for my PT61 and still had to send it in becuase other areas of the turbo were out of tolerance and I needed a new complete center section.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  14. #14 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    hmm yeah ima have to see if my turbo is bad or not. hope not but if it is. what size turbo should i go for?? i dont even know the size of this cartuning turbo lol. im new to the turbo world, i had a 12sec xp cam gtp before but never turbo
    TURBO GT.. ETC ETC
  15. #15 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2011
    Columbus, OH
    What turbo kit do you currently have?
    Other mods? and HP goals?
  16. #16 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2013
    wyoming MI
    i have a cartuning turbo kit with air to air i/c 60lb injectors,jasper race trans, zzp tune,everything else is stock right now my whp is at 278 and tq is at 379. i am looking to reash around 400-450max nothing too big. i am looking into a st3 turbo cam
    TURBO GT.. ETC ETC
  17. #17 Re: HELP! white smoke out of exhaust after accelteration ??
    Feb 2008
    NY
    Car tuning kit came with a p61. I upgraded to a T67. It all depends on how much you want to spend. It's cheaper just to change the seal.
    I'll post pics of what a bad seal looks like.
  18. #18 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2011
    Columbus, OH
    I have a very similar setup and currently at 348whp/512wtq.
    Do you have an exhaust cutout?
    With you goal of 450whp max I've seen a lot of people having great luck with the Precision PT6262. It will easily put down the power that you're looking for. Shop around and if you have the PT61 which was an upgrade for the Cartuning kit I would say have the turbo rebuilt as the PT61 is more than capable of making the power that you're looking for and will be the cheapest route to take.
    Standard Cartuning kit came with a T04B turbo (2.75" inlet/2" outlet)
    Upgrade Cartuning kit came with a (PT61) T04E turbo (3" inlet/2" outlet)
    Stattama offered and even bigger upgrade which is was Sal (Silver2kgtp) is talking about which is a T67 T04E (3" inlet/2"outlet)
  19. #19 Re: HELP! white smoke out of exhaust after accelteration ??
    Feb 2008
    NY
  20. #20 Re: HELP! white smoke out of exhaust after accelteration ??
    Apr 2011
    Columbus, OH
    May have to re-size the pic but this is from my PT61 that I just sold (I'm upgrading just like Sal )
  1. Transmission slips then fails; white smoke exhaust
    By rtwash89 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2012, 01:35 PM
  2. Can't tell between white smoke and exhaust
    By steeck1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2011, 12:05 PM
  3. white smoke :'(
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 10:50 PM
  4. white smoke.
    By gtpinsc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 12:08 PM
  5. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-10-2010, 06:29 PM
