What fuel rail would you recommend I use with a l26 uim? Thanks!
I have the PRJ rails and love them.
if your going for looks get PRJ rails or ZZP billet rails maybe even ZZP modded rails. if you just want to make it work im thinking L36 rails not sure if the L67 rails will fit i know L26 and L32 rails will not work on a 97-03
I use ZZP modded rails and they were a ***** to get seated with a L36 UIM. You could always hack up your L26 rails use fuel hose.
If I had to do t all over again and I had the cash I'd throw down the coin and get some PRJ rails.
Which heads are you using? I'm pretty sure the l36 rails will fit over the l26 intake.
