Thread: Upgraded to an A2A IC System.
Results 1 to 20 of 27
  1. #1 Upgraded to an A2A IC System.
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Sup all? It's been a while since I've posted.
    I'm finished with the A2A set up upgrade. I had the ZZP W2A IC system. I kept it when I upgeaded to turbo since it always worked and I didn;t have the money to upgrade. I'm upgrading now because the W2A is holding me back around 75+ whp.
    The install went pretty good. The only major things I had to do was cut away some metal from car itself so the piping would fit w/o hitting anything. I had to cut some the bracket that holds the bumper support. This way the pipe wouldn't hit the fog light housing. I had to cut away some metal where the pipes come into the engine bay. The piping obviously has to be cut to match each other when connecting them since it's a custom kit.
    The IC core I got from treadstoneperformance.com. I ordered the piping from cxracing.com and I ordered a piece of Phenolic material online to make a spacer between the UIM and LIM. I wanted to keep the 2.5" spacing that the W2A IC core had. Keeps the piping off the turbo housing. I also upgraded to PRJ plug wires and added a tranny cooler fan.
    Here a bunch of pics. A lot of the piping was straightened out.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: Upgraded to an A2A IC System.
    Oklahoma
    Very nice. Im curious as to where you got the fan for the tranny cooler?
  3. #3 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    Jegs
    Flex-a-lite 106 - Flex-a-lite Reversible Pusher/Puller Straight Blade Fans - JEGS
  4. #4 Re: Upgraded to an A2A IC System.
    Oklahoma
    Excellent, thanks for that information.
  5. #5 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    No prob
  6. #6 Re: Upgraded to an A2A IC System.
    SE Level Member TurboGTP's Avatar
    Cali
    Where did you get your Intercooler Piping & what Angles did you go with ?
    Show Me The Boost
  7. #7 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    Quote Originally Posted by TurboGTP View Post
    Wow this thread is back from the dead. LOL
    Here is the info on the IC piping.
    I bought the piping from CXRacing.com.
    I emailed them and made a special order. The kits on ebay include pipes you don't need. I did have some piping left over but I rather have more then come up short
    Here is the piping I bought from them
    1 – J pipe
    3 – Straight pipes
    2 – 90º L pipe
    2 – 45º pipes
    2 – 45º hose couplers
    6 – straight hose couplers
    25 - T-bolt clamps (Some may vary in size if you have transition hoses)
    This does not include the transition hose couplers for the IC core, turbo and MAF. Sizes can vary depending on set up.
    2 - 3” to 2.5” (IC core)
    1 – 2” to 2.5” (Turbo)
    1 – 3.5” to 2.5” (MAF)
  8. #8 Re: Upgraded to an A2A IC System.
    Cali
    What size piping did you go with 2.5 or 3.0 & is that piping holding up to the boost ?
    Show Me The Boost
  9. #9 Re: Upgraded to an A2A IC System.
    Cali
    Oh sorry for bringing it back from the died.. I searched & found this thread.
    Show Me The Boost
  10. #10 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    The piping is 2.5". Holds up with no problems
    I'm glad this came up again. This way guys can see what is used for a turbo setup.
  11. #11 Re: Upgraded to an A2A IC System.
    Cali
    Ok i think i might just get that instead of buying the Intercooler Kit from ZZP & save some money.
    Show Me The Boost
  12. #12 Re: Upgraded to an A2A IC System.
    Kansas
    its safe to use wood on your car?
    SOLD 1999 GT Silvermist TS
  13. #13 Re: Upgraded to an A2A IC System.
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Gafford44 View Post
    ya know, that crossed my mind too. then i continuted looking at the pics and thought "damn, this guy knows what hes doin"
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  14. #14 Re: Upgraded to an A2A IC System.
    Banned - Busted For Scamming
    Feb 2009
    Its not wood its phenolic lol
  15. #15 Re: Upgraded to an A2A IC System.
    Kansas
    ok that explains lol i was so lost
  16. #16 Re: Upgraded to an A2A IC System.
    Jan 1970
    Maquoketa, Iowa
    Be careful, I believe Sal uses the car mostly for drag, so he has his own reasons to delete the front bumper support. If you get a large enough front mount, you would most likely need to do this also. Its not totally unsafe, but it is another piece of metal protecting you from really messing up yourself or the car.
  17. #17 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    It will be cheaper to get all the piping and front mount on your own. You can get a smaller FM, model# TR10 (I think), that should fit behind the bumper support.
    I will be making a bar that will go across in front of my car soon. This way I am a little protected.
    I really only use my car on the weekend if I have a chance and at the track.
  18. #18 Re: Upgraded to an A2A IC System.
    Cali
    Quote Originally Posted by Silver2kgtp View Post
    Yea i was thinking on getting the TR10 Cause my car is going to be a Daliy Driver. Well not all the time but for most weekends.
    Show Me The Boost
  19. #19 Re: Upgraded to an A2A IC System.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i see u have 2 cradle spacers under the aluminum cradle. whats the reasoning? just wondering
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  20. #20 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    Quote Originally Posted by bbptech View Post
    hood clearance because of the IC core under the intake. The SD hood was hitting with only one set of spacers.
  1. ABS System?
    By mcg_999 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2008, 10:40 AM
  2. ABS System
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 06-04-2008, 01:17 AM
  3. new car = new system
    By ninjamonkey in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2008, 05:43 PM
  4. How to put in a Nav system
    By gp04 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2008, 12:33 AM
  5. My system right now
    By Grandprixboy1224 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2008, 05:04 PM
