Thread: TB for Turbo setups
Results 1 to 8 of 8
  1. #1 TB for Turbo setups
    GT Level Member japslpr's Avatar
    VA Beach
    I have seen where a lot of people are using stock TB's or modified stock style TB's with turbos. Is anyone using the N* setup with a turbo? IF so, are there any benifits or headaches when using this TB?
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  2. #2 Re: TB for Turbo setups
    SE Level Member xXch0dyXx's Avatar
    The Fort
    not really a benefit in a big tb on a turbo setup like there is with the m90. m90 needs the extra air cause its a Suck through setup, with the turbo being Blow through, it doesnt need the same diameter for the same power.
    Once you reach mid 10's or so im sure it would help you a little. Probably have a little better throttle response with the N* on a turbo setup, but i doubt you would see or feel any gains.
    fwiw, gn guys run low 10's all day on a pos 62mm tb. and srt4's run 11's all day in the 50mm's. i know, apples to oranges, but thats over 400whp anyway you look at it
    01' Regal GS the DD-- S2 IC, slp headers, S1X w/rollers, 2.8"
    85' Grand National the weekend warrior-- L67?! 10's???
    07' Impala SSthe other DD
  3. #3 Re: TB for Turbo setups
    I live here. UR LOSN's Avatar
    Rockford, IL
    actually the more airflow you are able to move, the better. I have a BBK 90mm LS1.
    this is the same about the MAF sensors.....
  4. #4 Re: TB for Turbo setups
    The Fort
    the more air the better is true, but he wanted to know if there would be gains. Im willing to bet it he used a stock tb with a turbo setup (pending full build info) and dynoed, then used a N* or bigger he would see negligable gains ~5hp. Not worth the extra money if you ask me
    BUT, there is a limit to where you would see gains that warrant the expense.
  5. #5 Re: TB for Turbo setups
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by clubgpPwneD View Post
    I've seen a lot of turbo setups with the stock tb, some actually switched from N* to stock when converting their setups to turbo. I remember reading something from maybe Matt M about the benefits of the stock tb but i can't remember... lol Maybe it was something about the MAF on the stock tb or why they couldn't use aftermarket mafs?? Duckcall still has the stock tb and maf on his impala.
  6. #6 Re: TB for Turbo setups
    The Fort
    yea, i believe he does say there is a maf benefit but i wasnt taking that into factor. it is a valid point though. If you have an ls1/lt1 maf tho it shouldnt be too much of an issue to a competant tuner
  7. #7 Re: TB for Turbo setups
    You could use the billet ZZP TB 78mm for turbo setups.
    Wiz, Wideband O2, 78mm T/B, P&P SC, SSIC, P&P LIM, 3", 1.8CCRR's, CC push rods, Custom covers, SLP headers, Meziere Water pump 3" Magnaflow, Race Tranny, 20" Concept One Wheels, Coilovers, BMR F&R suspension, Custom Body and Paint, Custom interior and sound.
  8. #8 Re: TB for Turbo setups
    Aug 2008
    Flushing/Flint, MI
    Jeff has a stock TB but a modified stock MAF
  1. Wideband setups, tell me about yours...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 09-17-2009, 12:38 PM
  2. Turbo Charged GTP
    By RPM_INC in forum Turbo
    Last Post: 09-23-2008, 07:31 AM
  3. anyone know why my turbo does this???
    By lilredss0287 in forum Turbo
    Last Post: 08-23-2008, 09:11 AM
  4. Turbo Gxp!!!
    By PshnLck18 in forum Turbo
    Last Post: 08-18-2008, 12:23 AM
