Thread: anyone know why my turbo does this???
Results 1 to 6 of 6
  1. #1 anyone know why my turbo does this???
    Jul 2008
    i took of the intake tube that connects the turbo to the throttle and i seen some oil at the bottom of the throttle.....anyone no why the turbo would be spitting oil into the engine?? i no this is not good at all soo id like to no why soo i can get to fixing it!!!
    is there a way i can fix the turbo or do i need a new one?
  2. #2 Re: anyone know why my turbo does this???
    TDCRacing
    Guest
    Well, not to fimiliar on turbos yet but i will try to help. I'm sure if the oil is comming from the turbo that it at least needs a rebuild. I'm sure there are some type of seals in there that could be changed out. Are you sure it is comming from the turbo and not the pcv valve area? Maybe from engine blow-by
  3. #3 Re: anyone know why my turbo does this???
    Donating Users sra_chipmunk's Avatar
    Georgia
    Are you using the intake side of your turbo as a vaccume source for anything? For instance, I use it as a vaccume source for my crank case as you can see in the pic of my engine. Its the line going from the valve cover breather into the silicone bend.
    anyways, if you do, then you are probably getting blowby out of your breather due to the high boost you run.
    If not, then I would check your turbo for leaks. I have heard people say that is very easy to blow your turbo seal out when you apply to much oil pressure.
    Yeah its a grand prix, so what, wanna fight about it.
  4. #4 Re: anyone know why my turbo does this???
    I live here. UR LOSN's Avatar
    Rockford, IL
    oil restrictor is a must when running high oil pressure....
  5. #5 Re: anyone know why my turbo does this???
    GT Level Member japslpr's Avatar
    VA Beach
    sra_chipmunk...
    Nice engine bay...That is one clean setup. What turbo kit are you running??
    Concerning the question...
    You are either getting blowby from the PCV or your turbo seals are bad. Warm the car up to operating temp, shut it off, then remove the intake tube. Spin the compressor wheel and check for side to side play as well. If you have a bad seal leak, you should notice a good amount of oil build up all through the intake.
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  6. #6 Re: anyone know why my turbo does this???
    Georgia
    Quote Originally Posted by japslpr View Post
    sra_chipmunk...
    Thanks, Im running ZZP's Z-7 kit (T-62)
  1. Tuning for the turbo
    By TurboKent in forum Turbo
    Last Post: 05-27-2008, 10:33 PM
  2. ZZP power log on a turbo car?
    By Smokedgtp in forum Turbo
    Last Post: 05-07-2008, 06:07 PM
  3. T3 Garrett Turbo + GM 3.1L V6= ???
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-27-2008, 06:05 PM
  4. turbo manifold >?
    By sal3800 in forum Turbo
    Last Post: 04-09-2008, 06:33 PM
