Thread: Anyone running an EGT sensor?
Results 1 to 5 of 5
  1. #1 Anyone running an EGT sensor?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Just wondering if anyone is running one and has it been beneficial? I am thinking about getting a plx EGT sensor because I already have a plx w/b.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: Anyone running an EGT sensor?
    GT Level Member TurboKent's Avatar
    Woodward, OK
    i'm running one. have it about 7 inches behind the turbo. As far as beneficial it's just another check to make sure it gets the fuel it needs to keep cool. The more boost/load that you put on the engine the hotter the exhaust gases will be. Mine average around between 900-1000 degrees normal and go to about 1300-1400 under boost
  3. #3 Re: Anyone running an EGT sensor?
    GTP Level Member buickman104's Avatar
    NYC
    Then what temperature range would be considered the danger zone?
  4. #4 Re: Anyone running an EGT sensor?
    Woodward, OK
    i would think that anything above 1500*
  5. #5 Re: Anyone running an EGT sensor?
    Oklahoma
    Arent the pistons Aluminum? Isnt the melting point of aluminum in the 1200 - 1300* range?
  1. running a stop sign
    By tod1d in forum The Rant Forum
    Last Post: 08-06-2008, 06:48 PM
  2. MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 02:57 AM
  3. Who is running ARP head studs???
    By Trannyman95 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 03:29 AM
  4. HELP!! My GP is Only Running On 5 Cylinders!!
    By y1a3o in forum General Tech Discussion
    Last Post: 05-14-2008, 11:20 PM
