Thread: ZZP power log on a turbo car?
Results 1 to 17 of 17
  1. #1 ZZP power log on a turbo car?
    SE Level Member Smokedgtp's Avatar
    I was thinking of maybe picking up a ZZP power log. Are these good on turbo cars? Im running a stock front mannie and a ported rear with #6 turned. Would a power log be a good idea or should I just install the ported front I have?
    Thanx guys
    CT 61mm turbo, 3" DP, DHP tuners, SD spoiler, SSC springs, 17" mustang wheels, and much more
  2. #2 Re: ZZP power log on a turbo car?
    Oklahoma
    I think you would be fine, furthermore I do believe they also have a manifold for the rear as well that is like the plog but set up for a turbo.
  3. #3 Re: ZZP power log on a turbo car?
    TDCRacing
    Guest
    correct...zzp does sell a powerlog for the rear and is only available for the turbo guys...since you are going turbo'd sounds like your looking for some reasonable power down the road...just think about want you want from your car...then what you need parts wise to make it happen. that way you may be able to save yourself some money down the road.
  4. #4 Re: ZZP power log on a turbo car?
    Barksdale AFB, LA
    Just make sure you get the higher quality powerlog since the non-stainless ones can crack under the heat from a turbo.
    North American Impala Owners Association Forums-viewtopic-Ticking in my engine bay.... Update!! My power is back kinda
    2009 Subaru Impreza WRX STI
  5. #5 Re: ZZP power log on a turbo car?
    Good info guys. Think I'm lossing power from this OEM Mannie? I was thinking a power log may even help with turbo lag. I have the ported rear now, This one ZZ Performance will not work on my CT kit b/c my waste gate goes over the stock outlet. Mine is a very modded stock rear. ZZP did do the work.
  6. #6 Re: ZZP power log on a turbo car?
    TDCRacing
    Guest
    Quote Originally Posted by Smokedgtp View Post
    holding you back? probably not...now anyway...more mods?? maybe then
  7. #7 Re: ZZP power log on a turbo car?
    Barksdale AFB, LA
    The stock front mani is holding every 3800 back. It sucks. Get rid of it.
  8. #8 Re: ZZP power log on a turbo car?
    Quote Originally Posted by TDCRacing View Post
    Mods are Ct turbo kit, A2A IC, 1.9 rockers, 3" mandrel exhaust, 42# injectors, DHP tuner, I have more im just drawing a blank. Im putting down 412whp so im thinking that mannie is killing me at this point. My last GTP was 390WHP and I had headers on it (but it was a GEN 5 IC set up)
  9. #9 Re: ZZP power log on a turbo car?
    TDCRacing
    Guest
    o i change my last answer...I would say that it is holding you back...I figured you had a basicly stock set up just swapped for a turbo and planned on modding it further down the road.
  10. #10 Re: ZZP power log on a turbo car?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    I thought we were talking about the rear mani...if not i would also agree to the above statement.
  11. #11 Re: ZZP power log on a turbo car?
    Barksdale AFB, LA
    He said he has a stock front mani, and a ported rear. I'd assume he's wanting to replace the front since he can't replace his rear (CT turbo kit) and hasn't done anything to the front yet.
  12. #12 Re: ZZP power log on a turbo car?
    Your 100% right
  13. #13 Re: ZZP power log on a turbo car?
    TDCRacing
    Guest
    my bad...yea go ahead and go as good as you can go with that
  14. #14 Re: ZZP power log on a turbo car?
    i have the front and rear on a z7 turbo kit it does help with spool
  15. #15 Re: ZZP power log on a turbo car?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Definitely ditch the front mani, and get a plog. I am now sure if it is still this way but they used to make a normal plog with straight primaries and a turbo plog with angled primaries. Make sure you get one with the angled primaries if you get a used one.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  16. #16 Re: ZZP power log on a turbo car?
    This is the one im looking at. Is it ok? I have the rear already
    ZZ Performance
  17. #17 Re: ZZP power log on a turbo car?
    New Salem, ND
    just make sure for option 1 you choose the 304 stainless
  1. My turbo update
    By UR LOSN in forum Members Rides
    Last Post: 04-09-2015, 07:09 AM
  2. T3 Garrett Turbo + GM 3.1L V6= ???
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-27-2008, 06:05 PM
  3. turbo manifold >?
    By sal3800 in forum Turbo
    Last Post: 04-09-2008, 06:33 PM
  4. Replies: 16
    Last Post: 03-06-2008, 10:15 AM
  5. Turbo Videos!!!
    By x1FastGTPx in forum Turbo
    Last Post: 02-10-2008, 02:31 PM
