Thread: Average cost of going turbo?
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41 Re: Average cost of going turbo?
    SE Level Member BlackGS's Avatar
    Central Jersey
    Quote Originally Posted by ChrisGTT View Post
    Where did you get that filter? Ebay or also frozen boost? What size inlet on the filter?
    I got that filter from frozen boost with 3.5" inlet:
    Air Filter Media
    It didn't stay on very long. It was all mashed into the upper radiator line to make it fit, so I took it off and put on a K&N cone with a 45-degree coupler.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  2. #42 Re: Average cost of going turbo?
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    Quote Originally Posted by BlackGS View Post
    Air Filter Media
    Any pics? What size filter? Model #? Is it the zzp setup?
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  3. #43 Re: Average cost of going turbo?
    Jan 1970
    Maquoketa, Iowa
    He's got a T72 stattama setup i think they came with that 90* elbow and filter. Pic on the previous page looks like the mushroom is touching the radiator but has a coupler extending it, if they make a filter size large enough to just fit on the turbo inlet that would be ideal. Our cartuning kits have the inlet or turbo at an angle pointing towards the headlight more.
  4. #44 Re: Average cost of going turbo?
    Nov 2008
    NY
    Quote Originally Posted by FoSHO99 View Post
    Ya but it kicks the turbo forward like 3in. I can't find a K&N to fit in there without hitting the pcm or the headlight or the rad hose.
  5. #45 Re: Average cost of going turbo?
    Jan 1970
    Maquoketa, Iowa
    I took some pics of mine, but lost the cable to my camera.
    Mines a K&N B035B4 filter, i can't find any info. on that #. It fits pretty good, but not sure what you would need since I have a PT61. I have 1 zip tie attached to the corner of the pcm and tightened so that it is wedged against the frame on the back of the headlight. It lays flat and hasn't moved, I have some header wrap on the wires close to turbo just in case.
    Flange 3"
    Bottom Outside Diameter 4.75"
    Top Outside Diameter 3.5"
    Top Style Rubber
    Length 5.75"
    Flange Length .75"
    Flange Angle 0
    Offset 0
    Search here:
    K&N Universal Round Tapered Cone Air Filters
    This one is probably the same as mine: RU-5111 - K&N Universal Air Filters, Universal Rubber Filter
    You would just have to measure your inlet on your turbo and make sure the 3" flange will fit on there.
  6. #46 Re: Average cost of going turbo?
    Central Jersey
    Here are a couple pics of the filter now. I think this is the filter that originally came from the Stattama kit. I'll try to find the product number if I still have the box around anywhere.
    I had to cut the coupler a little bit to get the angle right. That coupler was originally a 90* bend.
  7. #47 Re: Average cost of going turbo?
    Damn...that is such a tight fit from the way I'm looking at it...
  1. Cost of paint job?
    By Nickell in forum Off Topic Discussion
    Last Post: 01-26-2010, 08:32 AM
  2. Cost for LIM fix in the Minneapolis area
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 10:25 PM
  3. L67 cost
    By nicksilvergt99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2009, 08:53 PM
  4. cost of top swap
    By skidoojames151 in forum General Tech Discussion
    Last Post: 08-05-2009, 09:44 AM
  5. Average gas mileage.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2008, 11:49 AM
