Thread: any regular maintenance checks on the turbo?
Results 1 to 4 of 4
  1. #1 any regular maintenance checks on the turbo?
    since being new to the turbo side, i was wondering if there are any maintenance to be done/checked on the turbo or any of the other parts of the turbo setup, sic as BOV, WG, I/C, etc? like how the m90 needs its s/c oil to be changed every so often depending on how hard its being used as well as checking the conditions of the rotors and so forth.
    also i have a catless straight pipe after the turbo downpipe. im using a 80/20 methyl alcohol to water mixture that sprays once i reach 10psi. the car shoots fireballs when letting off after going WOT above 10psi(remember alky sprays at 10psi+) good for the turbo? also my friend said while i was going WOT(at night) he said he saw blue flames coming from the exhaust. is this from the use of methyl/rich gases escaping?
  2. #2 Re: any regular maintenance checks on the turbo?
    pic of the catless pipe that im talking about that shoots fireballs and emits blue flames when at WOT:
  3. #3 Re: any regular maintenance checks on the turbo?
    Jersey
    Since there is a line feed to the turbo, i don't see why or how you would change it, until u change your motor oil. Sometimes the oil seal breaks/faulty in the turbo (happend with my friends evo) and you will smell the oil burning through your hvac vents.
    as long as your setup isn't doing this
    YouTube - True Compressor Surge
    YouTube - Compressor Surge - Grand National
    or if your getting flutter dump, and runs properly then i wouldn't worry to much. As far as the flames go, its most likely due to the meth/catless/fuel mixture (my friends gt35r evo spits flames all the time). Maybe someone else will chime in since i only know very little about turbo's
    btw i am really jealous, i want turbo and flames
    16' wrx sti- stock
  4. #4 Re: any regular maintenance checks on the turbo?
    hmm ic. well my Tial BOV is working fine and its not making the compressor surge like mentioned. i do smell fuel/carbon monixide since my straight pipe is like directly underneath the shifter when the cars stationary 0.o....the catback/side exit will be reinstalled when i go for the yearly inspection. its sitting currently outside in the backyard. maybe i should cover it/shelter it form the rain -_-
  1. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
  2. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
  3. Disabling my failing emission code checks for emissions this week
    By Quicklynx in forum General Tech Discussion
    Last Post: 03-24-2009, 07:30 PM
  4. Low maintenance mods.
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-13-2008, 04:15 PM
  5. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
